![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 ![]() |
Will this unit enable the park heat function ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35520 ![]() ![]() |
if you have the actual fbh , then yes.. ... - .- -.
it'll be best to wait for steve/pat to answer this one...can you update your car profile so they/we know what range you have .. ... - .- -.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
You can switch it on and off using the tool. |
Exactly. Thanks, Paul. The instrument cluster will need a reboot to show the change in the timed climate menu. Earlier cars could do a 'reset' via the 'secret menu' in th cluster (google), but it is just as easy to do a short batt disconnect (follow RR battery disconnect / reconnect procedures!). ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 ![]() ![]() ![]() |
Hi Guys
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233 ![]() ![]() ![]() |
Why does FMH not work for me? I have FMH enabled using fog lights and position lights, with a 40 second delay (which I presume is the length of time the lights stay on). But the lights never come on. I keep the light switch on the dash set to auto - does that have anything to do with it?
do you 'flash' the main beams before you leave the range... ... - .- -.
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
my lights have to be on when i switch the car off,then when i switch of the lights they stay on for around 40s even after locking the car.
05 onwards you need to turn off engine then flash your main beam to turn on FMH
Oh, I didn't know about having to flash main beam! Thanks for the heads up - I'll try that later. |
Where is the best place to purchase this unit considering daveo troubles ? |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 603 ![]() ![]() ![]() |
Got mine from LRPARTS online quickly and for a good price. Others have done better still. Check out this thread page 11 on...
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 ![]() ![]() ![]() |
Got mine through Len - salop4x4@gmail.com Very easy to deal with, and very promp in replying to emails, and posting unit out. ![]() |
