![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
@Turbo Tony
Stan and TurboTony are exactly correct. This only applies from 02-04, tho. As of 05 it's gone. So flipping it won't help, miller... From the RTFM ![]() ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
@Steve
KARMANN Member Since: 13 Dec 2010 Location: Scotland Posts: 95 ![]() ![]() |
Hi there, looking for some info. Recently been having issues with the engine management light. After being ripped off with the dealers im refusing to let them at the car again.
Update to previous post-with regards to mpg fitted new MAF still nothing. As for reading engine fault codes still getting 'NO COMM WITH ECU' any ideas, anybody? New ecu?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35658 ![]() ![]() |
we can help you with that, as for your fault codes it appears nobody knows.. ... - .- -. Y. O. L. O. . |
Hi Fraser, Sorry for the late reply. When the IIDTool has no comms with the engine ECU, it is usually either that the IIDTool is being used with the key in the accy (radio) position rather than ignition or there is a connectivity problem on pin 7 of the OBD connector. Please check the following: do you get a 'Safe Mode' message when you enter the menu? Is menu navigation slow (1-1000, 2-1000 per click rather than 1,2,3...)? If you have not been using the IIDtool in accy position, please check your OBD connector on the vehicle. The 2 'tounges' in the pin 7 connector may need to be bent inwards with a jewelers screwdriver or pin. Please let us know how you get on. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
I had a similar issue with slow response times and no comms.
ok, I will be getting my tool as soon as I am back from a few days away, wanted to ask a few questions , can you make a total back up of your car so if you mess up something you can put it back how it was..
i believe you can save before you start playing dave, it appears that you can activate the rain sensor but it depends on your bcm, and menu/sub menus are on post number one and on the GAP site.. ... - .- -.
Thanks Stan |
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 ![]() ![]() ![]() |
Hi Guys
the original restore on the eas is a welcome feature pat |
I always use the IIDtool with the engine running. Im not sure I understand what you mean by slow reponse 1-1000, 2-1000 etc. The tool always works in any other function as far as I can remember. And has previously worked in the Engine ecu part showning faults, but not recently when iv tried. If I look at the end of the OBD connector what pin is pin 7? Many thanks Fraser Last edited by KARMANN on 23rd Sep 2012 3:40pm. Edited 1 time in total |
