Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 12 of 49 <123 ... 111213 ... 474849>
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
Thanks Steve - I don't know what the key number is so I'll set all of them to "yes". That should sort it! Very Happy
Post #139465 4th Sep 2012 7:56pm
Cash2
United Kingdom 2018 Range Rover Autobiography TDV6 Santorini Black
3 Flash Turn
Can anyone help with the enabling of the 3 Flash Turn using the IID Tool, I have tried several times but no success.
Many thanks
Post #139468 4th Sep 2012 8:05pm
there isn't one, is there? ... - .- -.
Post #139478 4th Sep 2012 9:02pm
Cash2
3 Flash Turn
The option is there in the Instrument Pack - I have two options 1) 3 Flash Turn Enabled and 2) 3 Flash Turn Enabled.
I have tried entering yes to both but still no joy - I have an 06 TD6.
Post #139482 4th Sep 2012 9:47pm
mine hasnt got it listed and i've looked at the 2006 IPC-instrument pack features and there isnt that option listed either only a 'service interval reset'..
are you getting this on the dash readout ? ... - .- -.
Post #139513 5th Sep 2012 7:38am
Cash2
Hi Stan
I am getting this on the dash read out but I will double check it again in an hour or so and post a photo for info.
Post #139534 5th Sep 2012 8:24am
Cash2
Hi Stan
I have the photos but struggling with how to post them with my reply, any clues?
Post #139557 5th Sep 2012 10:14am
millerj90
Wiper Speed Step-Down
Located in the BPM - Body Processor Section -" Wiper Speed Step-Down"
Can anyone let me know what this parameter refers to?
Current Setting = No
Many Thanks
Post #139589 5th Sep 2012 12:17pm
@cash,
click on gallery underneath the fullfatrr.com logo,
on the black banner click on upload photos
click on browse and select your pic from your pc/laptop
click continue 4 times
click on your pic and it will increase in size and have the file info
click on and copy the bb code full size and paste onto your post
@miller, i think it slows down the wiper speed but i'm sure steve will be on here soon to advise.. ... - .- -.
Post #139628 5th Sep 2012 1:44pm
Cash2
@Stan
I tried and this is the result:
Sorry about the quality..
Post #139633 5th Sep 2012 2:10pm
Cash2
@Stan
I will take some clearer shots and post
Post #139634 5th Sep 2012 2:11pm
nubbin
Hmmm, still no success with the door entry. When I get in the car and drive, all the doors lock. When I stop and get out, only the driver's door unlocks with a double pull on the door handle. When I lock with the remote fob, there is a double locking sound, and the driver's door locks, followed separately by the other doors and boot. It did not do this until I changed to speed related lockiong.
I have tried various parameters but nothing makes a difference. Can anyone tell me what the correct settings are to open all doors an the boot once the SPL has locked everything, and you then get out of the car after stopping?
Also why does FMH not work for me? I have FMH enabled using fog lights and position lights, with a 40 second delay (which I presume is the length of time the lights stay on). But the lights never come on. I keep the light switch on the dash set to auto - does that have anything to do with it?
Post #139642 5th Sep 2012 3:01pm
Turbo Tony
Re: Wiper Speed Step-Down
Many Thanks
I think that's when the wipers slow down while the vehicle is stationery. Researching my first Range Rover purchase
Post #139647 5th Sep 2012 3:28pm
I don't believe there are any settings to unlock ALL the doors once they have been auto locked.
The only way to do this is either use the fob or the lock/unlock button under the hazard button.
There has also been some discussion about why all the doors don't unlock when the keys are removed in the same way that BMW's do. Both cars use BMW modules, so it's a bit of a mystery why BMWs do and Range Rovers don't! Got - 2017 SDV8 Autobiography in Loire Blue
Post #139654 5th Sep 2012 4:17pm
SteveMFr
Site Sponsor
Hi Cash,
Earlier versions of the Instrument Pack firmware do not support the 3 flash turn function.
So, activating it in the CCF does nothing for these.
The way most CCF reprogramming works - in a a nutshell - is that the ECUs in question receive certain command strings and flip a 'softswitch'. The IIDTool interface is basically just a 'virtual keyboard'. Hit a key and hit enter and the command is sent to the ECU. But if the ECUs firmware does not contain this option, nothing happens. This is why we can't allow fogs as DRL, mirror folding on lock, etc, etc. These items are just not there. It is possible to reprogram by reflashing the ECU. And then you can make these options available - theoretically.
Cash, you have a later instrument cluster (so the IIDTool displays the later CCF interface) but an early fw version in your cluster. Unfortunately this does not seem to support the 3 flash function. Sorry...
Steve
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #139670 5th Sep 2012 5:16pm
