![]() | Home > Maintenance & Mods (L322) > Damped opening of lower tailgate |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Excellent how to |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Received the bits from Dan this morning.
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
just to let anyone know who's interested in ordering a kit, the brackets are currently back ordered at the factory there is no ETA date available as of yet. You can paypal direct using - www.paypal.me/duckworthparts
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
Just did mine this afternoon,
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
All done, thanks for the "How To". Made the drilling much less stressful!
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
can you guys check my video out, i fitted the damper kit but it appears to have made no difference and the tailgate still drops and slams down, doesnt really slow the drop
Looks like it's fitted OK. Maybe the damper's faulty? Got - 2017 SDV8 Autobiography in Loire Blue
quite possibly, give me a ring Matt You can paypal direct using - www.paypal.me/duckworthparts
excellent service from duckworths as usual! Dan's sending me out a replacement to try
Matt,
You probably don't want to here this but I looks to me you have mounted the bracket too far from the car body , To work properly the bracket needs to be as low as possible on the tail gate. 2008 MY Supercharged
Happy to report successful fitting of kit following advice and guidance on this thread. Used the two M6 bolts supplied by Dan to fix the mounting plate. Not really enough depth of metal to get a good thread going having tapped out the holes with an M6 x 1.0 so didn't do these up too tight. Will have to see how they hold, but one sunny day may have the carpet up and fit nuts on the back. I also get the damping effect and then the final gentle "drop".
I fitted mine yesterday as above, i quickly found that the bolts weren't that secure. Put nuts on the back, that wasn't a two minute job |
