![]() | Home > Maintenance & Mods (L322) > led halo's |
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
Well done. |
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
Looking good! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
another great job dave. |
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
Dave
the mock up went well so i think i will whip out my lights and do the full job, the last two pic's dont do it justice as i had the light on the camera shut right down and it started to pic out the individual smd's, you would never get this effect with the normal eye, they appear as one light ring. V8 facelift Range Rover Autobiography 22" wheels.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I like that a lot |
OK, looking for a bit of feedback. i have all the rings mounted, they fit great.will post some pics when i get a mo, also redone the xenon conversion on my high beam, i have now found a way to fix the bulbs correctly,the kit i used allows you to flash at 75% brightness, it gives you about 1 second flash,, now what i wanted was a bit of feedback on how they should come on. they came with a relay with 2 switch wires, one for the ignition live and the other you can connect to your interior lights so the halos come on when you unlock the car..now i don't know if i will use the relay as they don't draw that much and i fault i could connect them direct.
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
They look very professional Dave. I would go for them to come on with the ignition and go off when the heads are on.
hi, yes i thought about having them go off when the lights are on but then i would loose the halo on the high beam but if its a legal req, then it will have to be, any one know if it is a legal point or do you have a BMW with halo's and do they go off. V8 facelift Range Rover Autobiography 22" wheels.
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 ![]() ![]() ![]() |
Excellent posting Dave. I'm seriously impressed & you deserve a huge pat on the back for that one.
i'm with stewart on this...have the halo's come on with ignition and off when mains are one..on main you probably wont see the halo's anyway ...i have my smd fogs wired like this using a drl switch of ebay. .. ... - .- -.
@daveo
As far as I can tell there is nothing in the regulations to to stop you using your led halos all the time the ignition is on irrespective of which lights you have on the car. I'm not even certain the Regulations apply to retrospective fitting of such led halos. They could possibly be considered "optional front position lamps" under the Regulations. From my experience of using led halos in foglights however I would suggest you might need to reduce the light output of your leds in light conditions in which you may use side lights or dipped headlights. The leds are very bright in these conditions and could conceivably cause dazzle to other road users. This is included in the Regulations for all lights. To avoid this with my leds I reduced the output to approx 70% of normal when selecting dipped headlights which seems to be acceptable. Because of the seperate dip and main beam lamps on the FFRR this means the leds are also dimmed on main beam as the dipped beams also stay on with main beam. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I'm normally not a fan of these things, but I'm really impressed by your work, Dave.
thanks for the reply's, i have also done some digging and it appears, if the halos are part of the headlamp them selves they can remain on with the head lamps but if the halos or DRL's are a separate unit then they should switch of when the main headlamp is on...now i think i favor the on all the time with the ignition just wondering if i need to use the relay or can i go with the ignition live in the headlamp..
