![]() | Home > Maintenance & Mods (L322) > led halo's |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6762 ![]() ![]() ![]() |
Even if it did, it's not the greatest bargain of the year! Got - 2017 SDV8 Autobiography in Loire Blue
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
wow just saw your work Dave - GREAT JOB ! |
Daveo ordered some halos they have six smds in each to give oem look. Just to confirm they work with 12 volt systems . if I'm connecting directly to sidelight wires I do not need inverter is that correct? Thanks Present :2008 TDV8 HSE
Oops double post. Present :2008 TDV8 HSE
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
if its the LED's[smd] and i think thats what you have ordered it will be 12v and you dont need an inverter unlike the CCF rings that do.
do the rings you bought have the plastic diffuser over the led's V8 facelift Range Rover Autobiography 22" wheels.
I believe they do can't link to pic on this phone unfortunately. Present :2008 TDV8 HSE
Daveo
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I like the concept, unsure of the black plastic holder. |
I think I will get away with it after painting my inserts black |
Yes indeed, that would work |
