![]() | Home > In Car Electronics (L322) > BM54 Amp Upgrade |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Here is a pic I have from my car, BM54 is just out of sight under the yellow arrow ;
Here is a screenshot from the RAVE manual ;
So I suppose the side with the multiplugs on, or the left side of the unit, when installed, would suit for connectors ? Mark 2011 Range Rover Vogue SE 4.4 TDV8 Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
nicedayforit just beat me to it...... |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
So contrary to earlier posts this "upgrade" does not include a software fix to give Aux input on a RR BM54 tuner then |
Baris Member Since: 06 Mar 2012 Location: North London Posts: 95 ![]() |
Cheers Mark. Next to the radio plug would be a good spot then.
Amp upgrade and firmware upgrade are 2 completely different things. |
The firmware upgrade will just allow the AUX to be selectable from the front screen.
Baris, in no way am I trying to be criticle of the services you provide I am just trying to clarify the situation regarding aux input. This feature is the missing "jewel in the crown" on a FFRR BM54 tuner and one that many RR owners would like. If you have a software/firmware upgrade that enables this feature for �40 then that is of great service to the forum and one which should be actively promoted. ![]() If however the aux input feature is not part of the portfolio of services you offer then that should be made clear because at present I don't think Mark knows whether he will be getting this feature or not ![]() ![]() Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone. SWMBO: 2022 RRS D300 Autobiography, Firenze Red. Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD |
Hi Andy,
hi baris, its dave i spoke with you monday about the firmware upgrade and then the aux input, a 1 meter lead will be enough to bring out in the boot, heres some picks of where the tuner lives.
[img][/img] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1976 Harley Davidson Iron Head Sportster |
ok , i think its safe to say the service baris does is, he replaces the amps in the unit, he also upgrades the firmware that will give you the aux input option only the hard ware is not in the unit as standard,yes it is in the bmw version of the same unit as when they done it for landrover it was the minus this.
Yes Dave, that is pretty much what you get when you upgrade the firmware. I did a test yesterday, did a prototype of the loom for the RCA AUX input. And it definately does work. Just a note though, unless something is plugged in to the AUX input, AUX will NOT come up on the screen when you press Mode. However, there isnt enough room for 4 RCA outs and another 2 RCAs for AUX. So I might just convert straight into a Aux female socket. Which will be cheaper to buy a cable for afterwards. Here is some more info regarding the Dynamic Routing (thanks to ccfj1) Without Dynamic routing. Normally, if TMC is enabled and you have a TMC disc in the nav drive (TMC= Green), then TMC signals are passed to the nav unit (via Classic radio), to the TMC message menu. You get icons on screen for when you hit traffic problems on the road you are on, if you are being routed (via the nav), then you will get a message asking if you want to be rerouted as there is a something blocking the road ahead. But you need to access the TMC info menu to see what the actual problem is. With Dynamic Routing. Same as above, but it will also display (and voice message) problems when not being routed as it "knows" what road you are on and where the hold ups are, and it will also offer alternate routes on screen. No need to access the TMC info menu to see what the actual problem is any more either as its done dynamically to screen. |
nice one baris, how about giving us some prices for forum users |
Right, the prices are as follows for forum members. �100 for amp upgrade. �40 for firmware upgrade. �50 for AUX out + �6 (signed) or �9 (special) postage. As soon as I have got the AUX in sorted out, and the parts in stock, then I will work out a price for you guys. For faulty units, you have 3 types of faults. 1-Amp failure, 1 or more speakers stop working 2-Loud squeal, or distorting caused by a faulty chip 3-No power to the head unit This one is a bit iffy, as there are more than 1 reason why it isnt producing power. Repairs are �100 + postage (as above). If you have faults 2 or 3, then I can do the amp upgrade for half price. Bonus if you have amp failure, as you get the amp upgrade to fix the fault anyway ![]() I have noticed however, the bm54s do not suffer with faults in the RR as they do in the X5s. Probably because of the simple reason that BMW placed the BM54s in the most stupidest spot possible, next to the battery under the spare wheel! This overheats the amps, and causes them to fail. Well that is my assumption anyway. Hope that clears everything up for you all. You can contact me via PM, email (xkalibar@gmail.com) or by phone, which Mark wrote on page 1. Last edited by Baris on 8th Mar 2012 12:00am. Edited 1 time in total |
