![]() | Home > In Car Electronics (L322) > BM54 Amp Upgrade |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
Many thanks Baris.
Baris Member Since: 06 Mar 2012 Location: North London Posts: 95 ![]() |
No, I meant the chances of having aux input is 95%, as I encountered 1 or 2 that still needed the firmware upgrade.
Random ! |
OK. Had radio out today. Seems I may be in luck ? Although it says SA35 FTW as opposed to SA32 ?
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Ok, I had my unit upgraded by Baris - amp, firmware, aux socket and bluetooth. It arrived back very quickly, but it's only recently I've managed to have it brought to Switzerland and I've just installed it.
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
I think I will go for the amp upgrade only as I am going to fit an Intravee so I have MP3 on the screen, I also want to get the tv upgraded to digital and to be able to run a multiplay DVD in the boot and reverse camera. I alredy have 2011 door panels (still looking for back ones) so hopefully will notice the difference in sound quality. One day your life will flash before your eyes......................................make sure yours is worth watching!
Made up the cable and connectors today. The M-71-1 connectors are the right size for the quadlock inner block. Inserted connectors into block, 3&4 for pos, 10 for ground, fired up the car, connected mp3 player to cable, cycled Mode switch on the OBC, nothing, no sign of AUX |
Happy to report Baris' firmware upgrade did the trick, I now have AUX-IN |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
Just put my BM54 back in after being updated by Baris, I got the Bluetooth streaming added and the iPod adapter (with a firmware update).
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Thread resurrection!
The FFRR BM54 unit does not - no socket at all. Baris can add one, as he did to mine. |
Oe_tuning Member Since: 08 Aug 2013 Location: Singapore Posts: 37 ![]() ![]() ![]() |
Might as well do BT streaming if you upgrade from Baris. I have both aux and bt stream (which is channelled through aux). I never use the aux cable, it's just so convinient having wireless connection |
Yeah, me too. |
Ramius Member Since: 31 Dec 2013 Location: Buskerud Posts: 4 ![]() ![]() ![]() |
Hi Baris.
