![]() | Home > Maintenance & Mods (L322) > Rear washer leak repair - the cheaper option! |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6779 ![]() ![]() ![]() |
A few folks on here have experienced a leaking rear washer motor which results in dirty brown water on the inside of the back window and onto the parcel shelf, so rather than replace the entire motor, and referencing other "how to's" on here, I've come up with a much cheaper alternative!
Neat repair job |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Damnit!
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Excellent howto and repair |
Cheers Alan |
Just to add to that excellent "How-To" |
I've found these screws on the Bay - http://www.ebay.co.uk/itm/3-5mm-x-6mm-Self...2a190bef88 I know it's to buy 50 pcs, but they're still as cheap as chips! ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35667 ![]() ![]() |
in the wiki now... |
RRRob Member Since: 24 Jul 2010 Location: Bury Posts: 123 ![]() ![]() ![]() |
If anyone happens to have a spare washer inlet could you let me know. My washer/wiper is good except for the washer inlet bit where the pipe goes on being broken off. |
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 ![]() ![]() ![]() |
Thanks for the 'how to' alanm_3.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Excellent write-up! |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
alanm_3 |
Its so much easier to hand over £140 and just bolt in a new one! |
Only if you're rich! |
