![]() | Home > Maintenance & Mods (L322) > Rear washer leak repair - the cheaper option! |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
or Lazy
Thanks fella this worked a treat today |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6766 ![]() ![]() ![]() |
alan Member Since: 16 Sep 2012 Location: Somerset Posts: 45 ![]() ![]() |
Just put the seal in mine as it started to leak after i cleaned the line out and replaced the NRV. You dont have to remove the spoiler/wiper arm to do this repair just remove the 3 30 torx mounting bolts and the 7 15 torx screws it only takes about 20 minutes |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Took mine apart at the weekend and yep full of brown gunk - cleaned it all out - refitted it then snapped the top off the wiper arm spindle |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3895 ![]() ![]() ![]() |
Remember to bolt the spoiler back in place as if you don't this becomes a very expensive mod |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
I replaced my non return valve but even now if I've not used it for a bit it still takes a while for any water to come through......then its OK until left for a while....... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
I think I have this same problem. Got back from a trip last night in my FF after using the rear washer (never used before) and noticed yellow fluid running down the inside rear window and sitting on my parcel shelf (this would be the washer fluid).
I would take the spoiler off, makes life sooooo much easier . If it's been leaking, the chances are the motor assembly will be filled with brown, slimy greasy stuff that could go all over the inside of the car.
Thanks. I don't mind taking the spoiler off, it's whether I need to remove the wiper arm from the spindle or not. After recently fitting a new one and the previous one I removed and binned being badly corroded, I would ideally prefer not to have to take the newly fitted arm off the spline again.
If you're going to take the motor out to work on it (preferred) you need to take the wiper arm off the spindle first. If you've recently replaced it, it should come off much easier.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
^ yep will come off a treat now if it's been off recently. So much easier to work on the mechanism on the kitchen table👍 There is nothing that can't be fixed with a hammer😜😜
ok thanks chaps. I'll need to find a day when it's dry to do this job. |
This is the seal I have just purchased;
