![]() | Home > Maintenance & Mods (L322) > Rear washer leak repair - the cheaper option! |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6765 ![]() ![]() ![]() |
A few folks on here have experienced a leaking rear washer motor which results in dirty brown water on the inside of the back window and onto the parcel shelf, so rather than replace the entire motor, and referencing other "how to's" on here, I've come up with a much cheaper alternative!
4 x small screws to re-attach washer inlet to housing :-
Tools Required ========== T15 and T30 Torx bits 10mm and 13mm sockets small Posidrive screwdriver 2mm and 4mm drill bits Drill Rubber gloves! Method ===== - Remove wiper motor assembly as per - http://www.fullfatrr.com/forum/topic884.html?highlight=rear+wiper - Thanks to RRUK for this information. - Remove 7 x T15 Torx screws from motor housing and prise the two halves apart to get to the inside of the motor assembly :-
- Using the 4mm drill, drill out the plastic welds that hold the washer inlet to the wiper motor :-
- Remove washer inlet from wiper motor housing :-
- Fit Radial Oil Seal into the centre of the washer inlet :-
- Re-align the washer inlet into the holes on the motor housing and use the 2mm drill to drill small pilot holes. - using the small screws, re-attach the washer inlet to the motor house. It will sit slightly proud of the housing, but since the water goes through the centre of the inlet, this doesn't need to sit flush or be water tight :-
- Reassemble the motor assembly using the 7 x T15 Torx screws and refit as per RRUKs post. Got - 2017 SDV8 Autobiography in Loire Blue Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
Neat repair job |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Damnit!
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Excellent howto and repair |
Cheers Alan |
Just to add to that excellent "How-To" |
I've found these screws on the Bay - http://www.ebay.co.uk/itm/3-5mm-x-6mm-Self...2a190bef88 I know it's to buy 50 pcs, but they're still as cheap as chips! ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
in the wiki now... |
RRRob Member Since: 24 Jul 2010 Location: Bury Posts: 123 ![]() ![]() ![]() |
If anyone happens to have a spare washer inlet could you let me know. My washer/wiper is good except for the washer inlet bit where the pipe goes on being broken off.
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 ![]() ![]() ![]() |
Thanks for the 'how to' alanm_3.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Excellent write-up! |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
alanm_3 |
Its so much easier to hand over �140 and just bolt in a new one! |
Only if you're rich! |
