Home > Technical (L322) > FBH Not working on my TD6 Help! |
claud Member Since: 15 Apr 2009 Location: Godalming Posts: 103 |
Ambient needs to be below 6 deg C. 2018 Range Rover Autobiography
18th Jan 2012 10:29am |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 |
Paul
18th Jan 2012 7:09pm |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
I had the same problem. I haven't fixed it, but this works for me. After the fbh is turned on, I unlock the car with the remote. Then the hot air starts to blow in the cabin. |
18th Jan 2012 7:25pm |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 |
Hi cliffy
18th Jan 2012 10:16pm |
Hi JR,
19th Jan 2012 1:50pm |
Diver Bryn Member Since: 16 Jan 2012 Location: Durham Posts: 34 |
My TD6 did the same I removed the fuze and left it out over the summer. Replaced it in the winter and it appears to have rectified itself.v(Fingers crossed) Diver Bryn Previous Transport: Honda CB250n Toyota Starlet Renault Fuego 2 ltr TX Fuego Turbo BMW 528i Escort RS Turbo Capri 2.0 L Ghia Kawasaki GT750 P4 Mini Metro Ford XR2 Volvo 740 TDi Estate Mondeo Tdi Volvo V70 Tdi Mercedes E300 TDI Mercedes E320 Cdi Mercedes S320 Cdi Land Rover Discovery 3 TDV6 Mini Cooper Diesel Mercedes Vito Van 111 Range Rover TD6 VW Golf 2ltr GTD 2015 Year 2016 Audi Q7 Sline 3ltr 272Bhp |
19th Jan 2012 8:40pm |
Jr i have tried what you said but in the handbook it states key position 1 and still nothing when the manual softkey is pressed. On the timed climate section it says on the screen 30 minutes timed heating or ventilation which is based on a ambient temp of 16c ie above 16c it vents and below it is supposed to heat. When i select timed mode the fans come on ok but no heat even when its freezing in Wales!!! As i say i know the FBH works when heating the engine (which comes on at about 7c although the it is upposed to be 5c but then i dont suppose the sensor is that accurate) as i have seen the fumes and felt the heat out the FBH exhaust. It is just getting to be one of those little frustrating things that you can not let go off!! |
19th Jan 2012 10:22pm |
Cheers Steve but 1 day late
19th Jan 2012 10:26pm |
Hi Renegade2
19th Jan 2012 10:38pm |
Hi JR
19th Jan 2012 10:49pm |
By FSR you mean the hedge hog lol
19th Jan 2012 10:52pm |
Yes the hedgehog, need to be a midget to get up there, mind it was my own fault as i did watch properly when i took it out and therefore could not get the orientation right going back in!!! Learnt a lesson there!
19th Jan 2012 11:00pm |
Think I did the same 2 secs to remove a half an hour to refit
19th Jan 2012 11:47pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Same here |
20th Jan 2012 12:06am |
