Home > Technical (L322) > FBH Not working on my TD6 Help!
Page 3 of 4 <1234>
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Is your battery ok paul b,
Have you had it tested ?? RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #102537 20th Jan 2012 1:15am
Renegade2
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Checked battery which was low so put my MXS10 on overnight, battery is fine now but has not made any difference to the tocuhscreen menu, on timed fans come on no fbh, press the manual soft key no fans or fbh.
I think i would have rather not seen it in the first place but as it is there!! LR are just so frustrating at times!!!!
Post #102841 21st Jan 2012 4:39pm
Jr-auto-electrics
Just to compare is there any one else with the same spec car
With fbh and touchscreen and compare there's to see what they get.
Not 100% on this but I think the fbh gets two signals one from the car as can-bus
When using timed and screen controls and the other is.
When the fbh it's self is below 5c and gets voltage from the car when you start it,
This then fires the fbh as yours does.
So it could be the can-bus in the fbh ecu,
I'm not 100% but may be worth a little look in my rave.
Do you have one for your car as I've got the non touchscreen RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #102853 21st Jan 2012 6:39pm
Jr-auto-electrics
Just looked at my copy of rave,
Does any one have a copy for an 04 td6?
There are two controls going to the FBH on my car anyway
First is from the remote receiver this is a stand alone 12v signal to start the FBH,
once started the FBH then sends a can-bus signal to the HEVAC asking it to start fans etc.
Second connection is the can-bus (same as above) which receives the signal to start the FBH
from the Instrument Pack (touchscreen) etc and this is linked in with the HEVAC,
Ive just had a read of an older post with regards to non working aux FBH
does yours say AUX HEATING on the screen RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #102896 21st Jan 2012 9:09pm
This may be of use to you.
AC section page 82.26 onwards.
Wiring diagram
Post #102902 21st Jan 2012 9:54pm
Jr-auto-electrics
Cheers nice day for it
I've got the same drawing but with the
Remote wiring as well. RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #102909 21st Jan 2012 10:32pm
Renegade2
Hi JR
On the menu you select Timed Climate and that takes you to another screen where it says :
TIMED CLIMATE
30MINUTES OF HEAT OR VENT (no mention of Aux heating)
There are two timer settings and underneath a manual button, the handbook says that it works on a ambient temp of 16c above that it vents and below it is supposed to heat!! Manual softket i get nothing, timer setting i get fans but no heat and no FBH even trying to start. FBH works fine for the engine when it gets down to about 7c
I bet that new smaller remote feels better in your pocket
Post #103800 26th Jan 2012 11:43pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
i have exactly the same as above......
Post #103807 27th Jan 2012 12:05am
Renegade2
Paul i think landrover put there to tease us!!!!
Post #103812 27th Jan 2012 12:09am
Renegade2
I just read tis on another thread which i wonder if this is the reason that mine and Paulb fbh does not switch on from the touchscreen
"I had an indie to activate parking heating option with T4 - 5 min job and remote works. Park heater activation also enabled two timer settings and manual "heat on" function from MID (I don't have NAV)."?
Any one have access to T4?
Post #104024 28th Jan 2012 12:40am
M.D.610
Germany 2005 Range Rover Vogue Td6 Java Black
[quote="Renegade2"]Hi JR
TIMED CLIMATE
I've noticed too since the cold weather set in!!!
Exactly the same is happening with my TD6 Vogue 2005 touch screen job. I set the timer for the morning to start at 05:00
get to the car hearing some noises open it but inside is cold no heating just blowing cold air around.
Touching the manual option nothing happens!! but after a short drive to work get out of the car and can smell it. (smells like Kings Cross railway station on a busy day) in the day sometimes there's a little puff of smoke from under the car so I'm puzzled as to what it could be? any info would be appreciated.
cheers Current stock:-
FFRR Vogue
Post #105318 3rd Feb 2012 8:40pm
Jr-auto-electrics
Hi
Right aux heating is what is displayed on my TD6 non touch screen,
this gives you the same two timers and the aux heating or venting
yes if the temperature is below 16.c you get heat above this the car vents
if the out side temp is 7c or below the fbh will start-up with the engine
Do you have a remote?
if yes do you set your temp in the car to about 20c and have it in auto before turning the car off
and center vent turned to red?
if yes to all of these it may be worth a trip to the stealer to ask the question.
also does your remote flash if you have one after turning it on? RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #105335 3rd Feb 2012 9:21pm
M.D.610
FBH
Just been outside to try this manuel system on the timed climate control and the same thing started happening just venting cold air.......then all of a sudden it worked for about 10 seconds then everything went off tried starting the car flat battery within 10-15 mins so leads me to think the battery has had ists day and from what I can gather through this site the FFRR seems to be very sensitive to battery faults time for a new one ........ but what is recomended theres a whole heap of batteries out there!! 12v but what amperage is recommended? I don't know what is on it at present that I can check in the Morning but maybe it is the wrong one for the job!!
any info appreciated
Malc Current stock:-
FFRR Vogue
Post #105339 3rd Feb 2012 9:27pm
M.D.610
Jr-auto-electrics wrote:
Hi
Hi JR
No remote control. but I noticed I had to set the temp setting knob to full (both sides 26 degress I think) and the auto button in the middle had to be active then it worked but very briefly the battery went dead. I think it's time for a new one!! on reflection I just remembered before this business with the FBH I was refitting something or other and within 15--20 mins the battery was flat, had to borrow my neighbours jumpleads i understand the FFRR is susceptible to battery errors call it what ya will
NEW BATTERY REQUIRED...................BUT HOW BIG 12v /100-120
any info welcome....... my landy man dealer/stealer is chuffed with me I'll tell ya!! Current stock:-
FFRR Vogue
Post #105343 3rd Feb 2012 9:42pm
Jr-auto-electrics
http://www.battery2u.co.uk/type-I1-varta-car-battery-silver.aspx
This is the one I bought fantastic battery
No more faults on start up even at -5 RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #105351 3rd Feb 2012 10:05pm
Page 3 of 4 <1234>
