Home > Technical (L322) > FBH Not working on my TD6 Help!
Page 1 of 4 1234>
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Hi all
This is my first post on this forum, I was told about it by another member who has purchased a kit from me, any way
I have a few question and problems i need help with on my FBH,
My range is an o4 TD6 vogue, with remote FBH and sat nav screen etc.
Ive had the car just over a few years now and it has been great,
since owning the car ever time I unlock it or open a door after its gone to sleep etc
the FBH fan starts up for a minute or two?? Is this normal??
A few weeks ago the FBH started turning its self on in the cold morning as it should but after a minute once it had started up i get a groaning noise from that area which has to be the FBH never heard it before,( ive read other post on the groaning noise and its the same thing) but this is a new noise to my car.
the remote operation has been working fine until early this week, the groan has also stopped?
so i know the FBH is the problem so i do a few test etc.
after pressing the on button on remote or in the car, it fires the fan up for about 60 secs then turns off
More info if needed but can any one help me out if you've had this before .
great site by the way and hopefully Ill become an active member.
cheers Rob Very Happy
Post #101858 15th Jan 2012 9:07pm
Jr-auto-electrics
Just A little more info that I've just found out
When removing the fuse for the heater (F59) my FBH remote led flashes
which its never done before normally solid light.
manual states it should flash all the time?
what does ever one else remote do ?
your help will be appreciated RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #101883 15th Jan 2012 11:13pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
in past experience the usual thing to go wrong with the fbh is the little fule pump, its in a Censored place and it corrodes like hell. it sits just above the rear subframe, always worth a quick check before taking the liner out and digging deeper.
Post #101903 16th Jan 2012 1:38am
Jr-auto-electrics
Hi Arron
Ive checked out the pump tonight, it does look a little rusty,
so i tested the plug going to the pump by putting my test lamps on the end of it(12v bulb and some wire)
to see if i was getting the pulse from the FBH (clicking sound when normally running)
but no power or pulse.????
Ive been reading a few forums on rover 75s that have the same heater
and they are saying if the fan starts when you wake the car or unlock etc
its a sign its on its way out????
is it just my car or does any one else have the same when they unlock there TD6????
Think its going to be a new heater Censored RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #102031 16th Jan 2012 11:22pm
arron
oh that sounds like its going to dent your pocket then Crying or Very sad , my td6 is silent when i unlock it. the fbh only fires up after the engines running and the outside temp is low.
Post #102048 17th Jan 2012 1:12am
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
That, or move over here to Australia where you don't need one... Whistle
Post #102051 17th Jan 2012 8:32am
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
There is a lot of posts on FBH issues in the forum if you conduct a search.
I had mine replaced by main dealer under warranty, I believe it is a £1200 replacement item, but there are serviceable components.
Check this post out:
http://www.fullfatrr.com/forum/topic8960.html?highlight=fbh
And good luck, it is very annoying when they don't work, I went through a severe cold snap for three months without one brrrr! Big Cry 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #102091 17th Jan 2012 1:27pm
Jr-auto-electrics
Arron:
I've read somewhere that if you have a telestart (remote) the fan always starts when you wake the car etc
can any other TD6 owners confirm this???
The Brains Trust:
Id love too, is that offer from you Cool
Claud:
I read nearly 20 odd last night Yawn, and found some interesting stuff,
Tonight I've tested the pump with my old battery I removed a few weeks ago,
Pumps in great shape, that much so I got carried away and ended up with diesel dripping from the FBH exhaust. And then tried firing it up but still luck getting my mini jet engine to start Very Happy
So its not the pump.
Ive been through all the manuals for the heater and details of how they work etc, And I'm going to try changing the burner chamber first as i think the glow plug may have gone and a blocked gauze could be my probs
The heater starts & switches off etc as it should so at the moment I don't think its the ECU.
Does any one want me to take photos etc to do a post on stripping down the FBH. Whistle RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #102161 17th Jan 2012 10:00pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I have the 05 TD6
I don't have remote option.
My FBH seems to fire up and work correctly when the cars running. I hear it groaning and the pump ticking away. The exhaust gets hot.
BUT I can't get the cabin heating working via the timed setting, I just get the fans switching on without any heat.
Post #102172 17th Jan 2012 11:21pm
Jr-auto-electrics
Hi paul B
I take it you have sat nav. Have you tried the direct mode
With key in position 2.
And for the timed have you turned temp high and puts fan on full auto
Before turning the car off. RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #102176 17th Jan 2012 11:33pm
PaulB
Hi
Please explain direct mode
Post #102180 17th Jan 2012 11:45pm
Jr-auto-electrics
On your screen go in to aux heating then wait a few seconds
And you should be able to select the lower left corner aux heating
That's the instant way to start the fbh rather than setting the timer RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #102181 17th Jan 2012 11:56pm
PaulB
I have the touch screen and don't remember seeing that option.
Post #102182 17th Jan 2012 11:59pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
JR nice to c u on here fella Thumbs Up hope u get it sorted Thumbs Up
Neil
Post #102206 18th Jan 2012 10:26am
paul, your fbh will only work if the outside temp is below a certain limit ...or your battery needs replacing.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #102209 18th Jan 2012 10:35am
Page 1 of 4 1234>
