![]() | Home > Technical (L322) > Ongoing engine Fault Problem |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
See what your dealer will charge you then shop around but a dealer will probably be about �100 - �130 onto no6 Range Rover
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
Hi Steve,
SteveB Member Since: 12 Jan 2012 Location: Kent Posts: 56 ![]() ![]() ![]() |
Very Close then, are you about tomorrow anytime? Steve B
Yes mate, I'll PM you my number! Quis custodiet ipsos custodes?
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1049 ![]() ![]() |
If you buy a battery, and it makes no difference to any of these other faults, at least you'll have eliminated it as a possible cause. However batteries do always fail at around 5 years, and the first symptoms are always error codes relating to engine, gearbox and suspension.
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Just take the old battery out, leave for 20 minutes then fit new battery. Turn steering wheel from full lock one way to the other, that will reset the suspension and steering sensors. Do a search for other topics on battery disconnection, that should give you peace of mind. |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
Allways remove neg lead first as there is a pyrotechnic charge fitted to pos terminal |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1459 ![]() ![]() |
Agreed.
Right one massive Bosch battery purchased, so tomorrows job will be fitting it. I am sure my RR is listening however as when I pulled up at some lights half mile from home, it went to ideal then cut out, then when I went to turn over it fired then the engine fault warning come on again. Turn off and restart, all cleared again. Now a battery would not make the car cut out at ideal, or would it.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
dont forget to turn the steering wheel fully left ,then right to set the steering parameters after the battery install..... ... - .- -.
Thanks. Bonnet locked up, neg off first, wait 10 mins, then pos off, old battery out, clean up and make room for massive Bosch, fit new as far right, to outside as I can to make room for pos fitting, pos on first with pressive no faffing about, then neg on with pressure. Fire the RR up, turn full lock left, full lock right and all should be ok
Hey Steve, happy to help & if you get aggro again after the new battery has been fitted & you have gone for a drive, swing over & we'll hook her up again. Might also manage a cuppa - where was my manners, don't tell the Mrs! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
![]() From experience the big batteries just fit, no slack or space left or right. You will also look at the hole it has to go into and then look at the battery and have doubts, but it will go. Unless you are quite tall with muscles, use a small platform (not a plastic bucket!) to give yourself a bit more height and leverage when removing and fitting the battery. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Yes we will have to meet up again over a coffee and talk RR as my wife is fed up with me moaning about it. |
