![]() | Home > Technical (L322) > Ongoing engine Fault Problem |
SteveB Member Since: 12 Jan 2012 Location: Kent Posts: 56 ![]() ![]() ![]() |
Roll on Monday and getting my RR in to hospital for some tender loving care. Major Fault cascade again last night within 800 yards of leaving work. Stop, restart, another fault cascade, off again and restart, all ok. Now running like a dream but for how long. |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
The firm that I have been recommending is AHL Engineering run by 2 proper LR enthusiats who are brothers - Angus & Howard Leat.
Landrover Mad Member Since: 04 Jan 2011 Location: N.Ireland Posts: 35 ![]() ![]() |
Steve,
Thanks for the information. The more I can ask and know about similar fault problems the more I feel I can push for the answer.
Steve,
Well she goes in tomorrow morning for what I hope is the last time and all gets a fix. Had four more fault cascades over the weekend and a very hit and miss idle. But drives on the motorway like a dream.
Well dropped the RR in this morning with a full report on the last few days and the continuing fault problem. Not a positive reply from the service agent as they are as fed up as I am about it. Not earning nothing out of this repair. I was advised to sell it on fast if they cant find it this time.
That's what Roberts said about my wife's D3 EPB!
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Steve,
Get it back now and take it to these guys! The other lot sound like they've pretty much given up on it, you'll only get more bad news from them! 2012 SDV8 Vogue SE |
As odd as this may sound, when my 2010 lit up like a christmas tree and gave errors on every system, it turned out to be a fault with an ABS sensor. Nearly all the systems require input from the road speed sensors. so when they go off the scale - BONG.
Well, got the call from my service engineer and I am told that my problem might be the Fuel Valve Rail Pressure Sensor as the fault codes are pointing to it (makes logical sense, I guess). They are going to fit it and give me the car back for a week or two to trial. If there is no fault then all good, if the fault returns, back to scratching my head. Steve B
Hi Steve,
Original repair was the replacement of the fuel injection pump and sensor. I was told that they are one and the same so the whole pump had to be exchanged. Now they are going to replace the fuel pressure rail sensor. The you tube vid looks like the way to spot the fault.
