Home > Technical (L322) > Ongoing engine Fault Problem
Page 2 of 5 <12345>
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
See what your dealer will charge you then shop around but a dealer will probably be about £100 - £130 onto no6 Range Rover
Everyone needs a hobby
Post #101584 13th Jan 2012 3:43pm
piecost76
Hi Steve,
I'm in Wrotham so just the other side of West Malling on the A20 or M20 - 15 mins or so!
As to a battery, don't mess about, go for a 110 Ah, 920 CCA one from Euro Car Parts, nearest store is on the Medway City Industrial Estate:
http://www.eurocarparts.com/ecp/c/Land+Rov...amp;000020 Quis custodiet ipsos custodes?
15 MY 110 XS USW
54 FFRR Vogue TD6 Touchscreen - Gone!
56 FFRR TDV8 VSE - Gone!
Post #101588 13th Jan 2012 3:58pm
SteveB
United Kingdom 2006 Range Rover Vogue SE TDV8 Santorini Black
Very Close then, are you about tomorrow anytime? Steve B
RR TDV8 56 VSE
Post #101591 13th Jan 2012 4:03pm
piecost76
Yes mate, I'll PM you my number! Quis custodiet ipsos custodes?
15 MY 110 XS USW
Post #101592 13th Jan 2012 4:04pm
bozmandb9
If you buy a battery, and it makes no difference to any of these other faults, at least you'll have eliminated it as a possible cause. However batteries do always fail at around 5 years, and the first symptoms are always error codes relating to engine, gearbox and suspension.
It's incredibly uncommon in a Range Rover for it to get to the stage where it struggles to start the car, you always get electrical gremlins first.
Anyway, be interesting to see how you get on! Range Rover-less at the moment - Pining!
Post #101598 13th Jan 2012 4:21pm
SteveB
Changing a Battery
Are there any issues with disconnecting and installing a new battery. I have read some write ups that claim the RR locks up and you then need codes to make it all work again, is this true? Could it be as simple as take old battery out and put new battery in then all is ready to fire up again.
One listing says you have to use jumper cables to make sure you dont break the power connection to the RR? seems a little extreme but I am learning that the RR is a unique beast Steve B
RR TDV8 56 VSE
Post #101680 14th Jan 2012 11:04am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Just take the old battery out, leave for 20 minutes then fit new battery. Turn steering wheel from full lock one way to the other, that will reset the suspension and steering sensors. Do a search for other topics on battery disconnection, that should give you peace of mind. Smile No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #101683 14th Jan 2012 11:38am
oodathort
Allways remove neg lead first as there is a pyrotechnic charge fitted to pos terminal
Post #101689 14th Jan 2012 1:14pm
fisha
Agreed.
Only other tip is that when you reconnect the battery, dont treat the terminal gingerly.
Dont offer up the cable lightly to the terminal. Single solid movement to make it touch hard and complete the connection and hold it there whilst you wiggle it down onto the connector.
If you do it lightly, then its possible to have multiple touches and sparks as the connection gets closed. This can half wake up ECU's then switch them off again ... causing them to throw wobblers ( which normally clear if you disconnect the battery for a short time again ).
Doesn't always happen, but its has on occassions, and its been when I've been too timid with touching the terminal. V8 or else ...
Post #101690 14th Jan 2012 1:28pm
SteveB
Right one massive Bosch battery purchased, so tomorrows job will be fitting it. I am sure my RR is listening however as when I pulled up at some lights half mile from home, it went to ideal then cut out, then when I went to turn over it fired then the engine fault warning come on again. Turn off and restart, all cleared again. Now a battery would not make the car cut out at ideal, or would it.
Battery is low by the way. Thank you for the diagnostic tool this morning Ivor, massive help thanks. It showed a battery standing voltage of 11.6v, with charging voltage of 14.4v. So battery is low as so many have predicted, however the cutting out at ideal has got to be the injection pump as the fault codes might be saying.
Oh well, battery will be fitted tomorrow and I will see how this pump / ideal stability/ cutting out / engine fault problem fairs Steve B
RR TDV8 56 VSE
Post #101722 14th Jan 2012 5:50pm
dont forget to turn the steering wheel fully left ,then right to set the steering parameters after the battery install..... ... - .- -.
Post #101723 14th Jan 2012 5:58pm
SteveB
Thanks. Bonnet locked up, neg off first, wait 10 mins, then pos off, old battery out, clean up and make room for massive Bosch, fit new as far right, to outside as I can to make room for pos fitting, pos on first with pressive no faffing about, then neg on with pressure. Fire the RR up, turn full lock left, full lock right and all should be ok
How does that sound? Fingers crossed Steve B
RR TDV8 56 VSE
Post #101724 14th Jan 2012 6:03pm
piecost76
Hey Steve, happy to help & if you get aggro again after the new battery has been fitted & you have gone for a drive, swing over & we'll hook her up again. Might also manage a cuppa - where was my manners, don't tell the Mrs! Embarassed Quis custodiet ipsos custodes?
15 MY 110 XS USW
Post #101726 14th Jan 2012 6:10pm
Laughing
From experience the big batteries just fit, no slack or space left or right. You will also look at the hole it has to go into and then look at the battery and have doubts, but it will go.
Unless you are quite tall with muscles, use a small platform (not a plastic bucket!) to give yourself a bit more height and leverage when removing and fitting the battery. .
Post #101727 14th Jan 2012 6:10pm
SteveB
Yes we will have to meet up again over a coffee and talk RR as my wife is fed up with me moaning about it. Bow down
And Joe, I got the size covered 6'4" and a lump so lifting no problems....I hope Embarassed
Just hope the manic battery works and yes it looks way TOO big to go in but a few f's later I'll make it fit. That or it'll go in the boot with some long leads through the cabin Laughing Steve B
RR TDV8 56 VSE
Post #101728 14th Jan 2012 6:16pm
Page 2 of 5 <12345>
