![]() | Home > Maintenance & Mods (L322) > Rear Wheel Arch Rust Repair ? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
They just push on. No screws or anything. Cutting to length was the "hardest" bit, I did a test fit, without Vaseline on one side, and then cut the other side to match.
I wish someone had put them on mine a few years ago...........
highfellzippy Member Since: 20 Aug 2011 Location: Yorkshire Posts: 153 ![]() ![]() ![]() |
clean it off paint it with hammerite or stone chip ect
STEVE57 Member Since: 27 Apr 2012 Location: solihull Posts: 103 ![]() ![]() ![]() |
hi
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Mjd lists them earlier in the thread. And there is a pic of the label also.
hi
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 792 ![]() ![]() ![]() |
Just tidying up some bubbling at the moment. I put edge protectors on when I got it but this bubbling is more towards the inside of the rear door aperture and seems to be where the door curved weather strip comes in to contact with the body at the bottom of the opening. Could it be rubbing ? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
people put the strip on with a generous dollop of grease or other. I think the trick is to renew the grease etc once a year.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6762 ![]() ![]() ![]() |
Since it was such a fantastic day up here in God’s own country and knowing my rear arches needed some attention, I picked up the wheel arch strips a couple of weeks back, so today I though I’d make a start on getting rid of the rust.
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
I checked my recently acquired (last week) and it already has them fitted, an ‘07 VSE and always main dealer serviced so I assume it had been fitted if not from new but by the dealer at some time. David Please let me know if my comments upset you, I may wish to upset you again. |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
I got mine done a couple of years ago took bumper off and wheel arch protectors proper job done but just got a few bubbles coming bk now |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
I best order some quick before land rover realise what's going on and put the prices up by 3000% |
Rich_Allen Member Since: 05 Jan 2015 Location: Rutland Posts: 80 ![]() ![]() ![]() |
These are the ones that are fitted standard to the front of a Freelander 2. ![]() Just ordered a pair for my freshly done rear arches... 2008 TDV8 Vogue SE 2002 TD6 Vogue 2002 Defender 90 TD5 2002 Range Rover P38 Autobiography 2002 Range Rover P38 Westminster Just a sucker for big bills!!! |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I can't help feeling uncomfortable about fitting a trim to the wheel arch lip - it just seems like a water trap to me.
