![]() | Home > Technical (L322) > HID failure. |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 ![]() ![]() |
Swap the bulbs over and observe what happens |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 ![]() ![]() ![]() |
Mine has been doing this for the past couple of month. It started on the nearside but now alternates from 1 to the other.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
chris, check all the connections and then do what paul suggests....if its still flickering with the near side bulb in the it could be ballast failure ... ... - .- -.
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
I had the same with my offside Xenon, must admit i did not even know i had them until i took the lamp out and looked at it thinking to msyelf this not an ordianry lamp ££££££.
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
You can get the hid bulbs cheaper if you search around |
£16 for the pair delivered off ebay....i've had these type [6000k] for about 8 months with no problems.. ... - .- -.
For all of you that have a pre facelift FF, Why dont you buy a cheap cosmetically rubbish lamp off eBay for upto £30 (i buy them all the time for that kind of money) and you will have all the spares if one should start to play up on your car.
boffhead Member Since: 19 Mar 2010 Location: Norwich Posts: 42 ![]() |
I swapped the lamps over as suggested and the flickering seems to have stopped for the moment. I'm guessing it was a dodgy connection, but I did check this previously.
querky range rover electrics BOFF.. |
