Home > Technical (L322) > HID failure. |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 278 |
Swap the bulbs over and observe what happens
10th Jan 2012 1:43pm |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 |
Mine has been doing this for the past couple of month. It started on the nearside but now alternates from 1 to the other.
11th Jan 2012 12:36am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
chris, check all the connections and then do what paul suggests....if its still flickering with the near side bulb in the it could be ballast failure ... ... - .- -.
11th Jan 2012 8:52am |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 |
I had the same with my offside Xenon, must admit i did not even know i had them until i took the lamp out and looked at it thinking to msyelf this not an ordianry lamp ££££££.
12th Jan 2012 11:23pm |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
You can get the hid bulbs cheaper if you search around Reformed |
12th Jan 2012 11:27pm |
£16 for the pair delivered off ebay....i've had these type [6000k] for about 8 months with no problems.. ... - .- -.
13th Jan 2012 8:57am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
For all of you that have a pre facelift FF, Why dont you buy a cheap cosmetically rubbish lamp off eBay for upto £30 (i buy them all the time for that kind of money) and you will have all the spares if one should start to play up on your car.
13th Jan 2012 10:44am |
boffhead Member Since: 19 Mar 2010 Location: Norwich Posts: 42 |
I swapped the lamps over as suggested and the flickering seems to have stopped for the moment. I'm guessing it was a dodgy connection, but I did check this previously.
13th Jan 2012 3:50pm |
querky range rover electrics BOFF.. ... - .- -.
13th Jan 2012 4:51pm |
