Home > Technical (L322) > HID failure. |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 |
Swap the bulbs over and observe what happens
10th Jan 2012 12:43pm |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 |
Mine has been doing this for the past couple of month. It started on the nearside but now alternates from 1 to the other.
10th Jan 2012 11:36pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
chris, check all the connections and then do what paul suggests....if its still flickering with the near side bulb in the it could be ballast failure ... ... - .- -.
11th Jan 2012 7:52am |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 |
I had the same with my offside Xenon, must admit i did not even know i had them until i took the lamp out and looked at it thinking to msyelf this not an ordianry lamp ££££££.
12th Jan 2012 10:23pm |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
You can get the hid bulbs cheaper if you search around Reformed |
12th Jan 2012 10:27pm |
£16 for the pair delivered off ebay....i've had these type [6000k] for about 8 months with no problems.. ... - .- -.
13th Jan 2012 7:57am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
For all of you that have a pre facelift FF, Why dont you buy a cheap cosmetically rubbish lamp off eBay for upto £30 (i buy them all the time for that kind of money) and you will have all the spares if one should start to play up on your car.
13th Jan 2012 9:44am |
boffhead Member Since: 19 Mar 2010 Location: Norwich Posts: 42 |
I swapped the lamps over as suggested and the flickering seems to have stopped for the moment. I'm guessing it was a dodgy connection, but I did check this previously.
13th Jan 2012 2:50pm |
querky range rover electrics BOFF.. ... - .- -.
13th Jan 2012 3:51pm |
