Home > Technical (L322) > HID failure.
boffhead
HID failure.
My offside HID Xenon is flickering. Is this a symptom of lamp or ballast failure? It's only been doing it a couple weeks and you can hardly notice it.... Certainly not enough to bring up message on dash.
Any help appreciated.
Chris
Post #101013 10th Jan 2012 11:49am
Paul J.
Swap the bulbs over and observe what happens Question
Paul
Post #101024 10th Jan 2012 12:43pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Mine has been doing this for the past couple of month. It started on the nearside but now alternates from 1 to the other.
I've been planning on getting a new battery as I've had other electrical issues, this being 1 of them.
Hopefully that will sort it out.
Post #101107 10th Jan 2012 11:36pm
chris, check all the connections and then do what paul suggests....if its still flickering with the near side bulb in the it could be ballast failure ... ... - .- -.
Post #101112 11th Jan 2012 7:52am
Renegade2
I had the same with my offside Xenon, must admit i did not even know i had them until i took the lamp out and looked at it thinking to msyelf this not an ordianry lamp ££££££.
I cleaned up the coonection, put it back and not had the problem,since so worth agao as i think they are about £60 each?
Hope it works for you as it did me
Post #101445 12th Jan 2012 10:23pm
Reformed
You can get the hid bulbs cheaper if you search around Thumbs Up Reformed
Post #101448 12th Jan 2012 10:27pm
£16 for the pair delivered off ebay....i've had these type [6000k] for about 8 months with no problems.. ... - .- -.
Post #101469 13th Jan 2012 7:57am
For all of you that have a pre facelift FF, Why dont you buy a cheap cosmetically rubbish lamp off eBay for upto £30 (i buy them all the time for that kind of money) and you will have all the spares if one should start to play up on your car.
The ECU and Ballast are universal for both headlamps as are the bulbs, It can be taken apart at home or given to your indie or even your main stealer to keep parts bills lower... I think an ECU from the stealers is £160+ and the bulbs are £100+
I found it handy when i had one...
Craig Thumbs Up
Post #101501 13th Jan 2012 9:44am
boffhead
I swapped the lamps over as suggested and the flickering seems to have stopped for the moment. I'm guessing it was a dodgy connection, but I did check this previously.
Querky Range Rover electrics....... Or operator error Shocked
Post #101573 13th Jan 2012 2:50pm
querky range rover electrics BOFF.. Thumbs Up ... - .- -.
Post #101587 13th Jan 2012 3:51pm
