![]() | Home > Technical (L322) > New Battery and effects on driving |
Would be interested to hear from you if you have changed your battery on your FFRR and noticed a marked improvement on how well the car drives. I changed mine recently and Im confinced the car runs even smoother with more MPG . Thanks.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35499 ![]() ![]() |
it does seem like that, i sure the extra power does something to all the ecu's in the car and perks them up somehow... |
I was thinking the alternator does not have to work as hard and also electronic timing etc runs more efficiently |
the range starts quicker as well, or does it |
Yes Scarey but I wonder is it just imagination or does it really make a difference given the FFRR has a lot of electronics etc. If the older battery was maybe depleted to a point were it could only start the car its possible it may effect driving of the car especially if a couple of cells were faulty on older battery and car was only being used on short runs hence my thinking. Present :2008 TDV8 HSE
seriously i'm convinced the battery does make a difference..you and me have noticed it and many other members have posted about it.. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
I'm sure it's psychosomatic but it certainly starts with much more vigour - 920CCA.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1417 ![]() ![]() |
I suppose its a possibility if your old battery was really dud then a new one would make a good difference. The better the supply voltage, the quicker the coils will charge up and punch out a decent spark.
valid theory fisha.. |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
For the bit about spark, this would be valid for a petrol engine but not for your TD6! (according to the little car picture) |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
Yes i am sure it does all that and more mine even looks better with a new battery when parked up it shines more and i think it even sent me a txt the other day to say thank you ........ |
quite right sir.. ![]() Y. O. L. O. . |
Johninspain Member Since: 09 Oct 2011 Location: Murcia Posts: 7 ![]() |
Hahaha no way
L322Pilot Member Since: 10 Feb 2011 Location: Solihull Posts: 19 ![]() ![]() ![]() |
Before I replaced my battery I would get spurious massages on start up ranging from 'check light bulbs to steep hill descent inactive and more. New battery cured all and yes I do think the car runs better, well
