Home > Technical (L322) > New Battery and effects on driving |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Would be interested to hear from you if you have changed your battery on your FFRR and noticed a marked improvement on how well the car drives. I changed mine recently and Im confinced the car runs even smoother with more MPG . Thanks.
13th Sep 2011 6:41pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35419 |
it does seem like that, i sure the extra power does something to all the ecu's in the car and perks them up somehow... |
13th Sep 2011 6:44pm |
I was thinking the alternator does not have to work as hard and also electronic timing etc runs more efficiently Present :2008 TDV8 HSE
13th Sep 2011 6:46pm |
the range starts quicker as well, or does it ...it seems like it does.. |
13th Sep 2011 6:51pm |
Yes Scarey but I wonder is it just imagination or does it really make a difference given the FFRR has a lot of electronics etc. If the older battery was maybe depleted to a point were it could only start the car its possible it may effect driving of the car especially if a couple of cells were faulty on older battery and car was only being used on short runs hence my thinking. Present :2008 TDV8 HSE
13th Sep 2011 6:55pm |
seriously i'm convinced the battery does make a difference..you and me have noticed it and many other members have posted about it.. |
13th Sep 2011 6:57pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1518 |
I'm sure it's psychosomatic but it certainly starts with much more vigour - 920CCA.
13th Sep 2011 8:53pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1393 |
I suppose its a possibility if your old battery was really dud then a new one would make a good difference. The better the supply voltage, the quicker the coils will charge up and punch out a decent spark.
20th Sep 2011 11:16am |
valid theory fisha.. ... - .- -.
20th Sep 2011 11:44am |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
For the bit about spark, this would be valid for a petrol engine but not for your TD6! (according to the little car picture) |
20th Sep 2011 3:40pm |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 |
Yes i am sure it does all that and more mine even looks better with a new battery when parked up it shines more and i think it even sent me a txt the other day to say thank you ........ Far to many gone... |
20th Sep 2011 3:45pm |
quite right sir.. ... - .- -. Y. O. L. O. . |
20th Sep 2011 3:49pm |
Johninspain Member Since: 09 Oct 2011 Location: Murcia Posts: 7 |
Hahaha no way
15th Oct 2011 7:09am |
L322Pilot Member Since: 10 Feb 2011 Location: Solihull Posts: 19 |
Before I replaced my battery I would get spurious massages on start up ranging from 'check light bulbs to steep hill descent inactive and more. New battery cured all and yes I do think the car runs better, well
16th Oct 2011 9:26am |
