Home > Technical (L405) > pdc/park assit
Page 3 of 4 <1234>
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
so i cleaned connectors plugged it back in ran gap tool cleared error codes ,now when i press the parking sensor on info sys i get a bing but when i walked around the car nothing from the sensors so not convinced its sorted oh and i didnt get the bong and message saying parking aid problem Confused will see what happens when i drive it ....think i may have a sensor problem as well
Post #703723 4th Nov 2024 1:58pm
will308f
Big Cry Big Cry took the range rover out today and got the parking message again bum....there is a replacement on its way so fingers crossed that will sort it out (well at least the parking aid problem ) just the parking sensor issue to sort
Post #703811 5th Nov 2024 3:55pm
will308f
got my replacement parking control module dose it need to be updated with gap tool or is it plug and go ,I've never had park assist before so very much in the dark ... learning as i go Thumbs Up
thanks will
Post #703913 6th Nov 2024 9:02pm
will308f
replacement park assist module arrived fitted fault's cleared ..........and guess what still not working no parking sensors and nothing happens when you press the park aid button Big Cry Big Cry ,had a look with gap tool and nothing really so im at a loss Censored Censored it could be something simple but i cant see it cameras all work not sure where to go from here if im honest.... i need a wat to confirm that the fault is not the module so i can put the everything back
Post #703968 7th Nov 2024 2:46pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Does the buttons orange LED light up when you press the park aid or select reverse? If it doesn't you could try holding it for 10 seconds, if it is working but not indicating it should throw a code for a stuck button. Do the other buttons on the left hand side switchpack work?
Very odd, maybe worth checking the ccf to make sure the park aid hasn't been disabled, but as you were getting the error before I think it unlikley. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #703974 7th Nov 2024 3:26pm
will308f
hi
i believe when i started the engine there was a orange light ,i did try pressing and holding on both the park assist and parking sensor buttons but no change i also did ccf relearn as is says in gap tool manual,with the old module i got module failure but the error codes with the new one was to do with cameras and sensors i believe really weird
Post #703998 7th Nov 2024 6:23pm
will308f
wifes just been intouch and said that she didnt get the bong or the message saying park assist not working so will see whats what when i get home if i can confirm that there is no error message/codes from the control module at least i can put everything back together
Post #704035 8th Nov 2024 11:47am
will308f
Right just checked myself and guess what …..yes the fault still there(thanks wife) this is the error code from gap
Did also try holding the buttons for more than 10 sec no change did also try ccs relearn but no good I don’t believe that two different modules would have the same fault
Post #704058 8th Nov 2024 2:53pm
i think you said in one of your many other posts that you've only had this FF for a few months so why not take it back to the dealer that sold it to you... ... - .- -.
Post #704060 8th Nov 2024 3:11pm
will308f
lol i would if they weren’t 400 miles away Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter, i think it’s something simple/silly and i can’t see it for looking at it …..i may have to take to a indy who i know …….just don’t like to be beat . what im not sure of is it the parking sensors causing the problem and the park assist it’s just an out come
Post #704061 8th Nov 2024 3:46pm
4RRS
Park assist will only operate if you have the parking sensor system up and running, I had one faulty sensor on the front outer that shutdown the entire front, side and rear parking aid and the park assist system (as park assist uses the front, rear and side sensors). I'm sure if you solve the Parking aid issue you will find that the park assist works.
May be worth asking GAP if the PDC module requires coding to the car? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #704062 8th Nov 2024 3:54pm
will308f
thanks for confirming my thinking (parking sensors causing) i have already emailed patrick at gap so just waiting on a reply i do have 3 sensors with paint worn off and look a bit rubbish may have to get them replaced and see what happens gap tool isn’t telling me anything about sensors
Post #704064 8th Nov 2024 4:03pm
Kot
I guess you are not one for reading the WSM Rolling with laughter .
The first page of module removal
If a new parking aid module is to be installed, configure the parking
aid module using the Land Rover approved diagnostic system.
 2018 SE SDV8 4.4 Byron Blue
Post #704084 8th Nov 2024 7:13pm
will308f
i did have a read but because i was getting error codes when i checked with gap tool didnt think i could do anything
Post #704087 8th Nov 2024 7:35pm
will308f
do you mean ccf relearn ?
Post #704098 8th Nov 2024 9:14pm
Page 3 of 4 <1234>
