![]() | Home > Technical (L405) > pdc/park assit |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 487 ![]() ![]() ![]() |
got my replacement parking control module dose it need to be updated with gap tool or is it plug and go ,I've never had park assist before so very much in the dark ... learning as i go |
replacement park assist module arrived fitted fault's cleared ..........and guess what still not working no parking sensors and nothing happens when you press the park aid button |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 288 ![]() ![]() ![]() |
Does the buttons orange LED light up when you press the park aid or select reverse? If it doesn't you could try holding it for 10 seconds, if it is working but not indicating it should throw a code for a stuck button. Do the other buttons on the left hand side switchpack work?
hi
wifes just been intouch and said that she didnt get the bong or the message saying park assist not working so will see whats what when i get home if i can confirm that there is no error message/codes from the control module at least i can put everything back together |
Right just checked myself and guess what …..yes the fault still there(thanks wife) this is the error code from gap
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35602 ![]() ![]() |
i think you said in one of your many other posts that you've only had this FF for a few months so why not take it back to the dealer that sold it to you... ... - .- -.
lol i would if they weren’t 400 miles away |
Park assist will only operate if you have the parking sensor system up and running, I had one faulty sensor on the front outer that shutdown the entire front, side and rear parking aid and the park assist system (as park assist uses the front, rear and side sensors). I'm sure if you solve the Parking aid issue you will find that the park assist works.
thanks for confirming my thinking (parking sensors causing) i have already emailed patrick at gap so just waiting on a reply i do have 3 sensors with paint worn off and look a bit rubbish may have to get them replaced and see what happens gap tool isn’t telling me anything about sensors |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1310 ![]() ![]() |
I guess you are not one for reading the WSM |
i did have a read but because i was getting error codes when i checked with gap tool didnt think i could do anything |
do you mean ccf relearn ? |
