Home > Technical (L405) > pdc/park assit |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 450 |
took the range rover out today and got the parking message again bum....there is a replacement on its way so fingers crossed that will sort it out (well at least the parking aid problem ) just the parking sensor issue to sort |
5th Nov 2024 2:55pm |
got my replacement parking control module dose it need to be updated with gap tool or is it plug and go ,I've never had park assist before so very much in the dark ... learning as i go
6th Nov 2024 8:02pm |
replacement park assist module arrived fitted fault's cleared ..........and guess what still not working no parking sensors and nothing happens when you press the park aid button ,had a look with gap tool and nothing really so im at a loss it could be something simple but i cant see it cameras all work not sure where to go from here if im honest.... i need a wat to confirm that the fault is not the module so i can put the everything back |
7th Nov 2024 1:46pm |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 248 |
Does the buttons orange LED light up when you press the park aid or select reverse? If it doesn't you could try holding it for 10 seconds, if it is working but not indicating it should throw a code for a stuck button. Do the other buttons on the left hand side switchpack work?
7th Nov 2024 2:26pm |
hi
7th Nov 2024 5:23pm |
wifes just been intouch and said that she didnt get the bong or the message saying park assist not working so will see whats what when i get home if i can confirm that there is no error message/codes from the control module at least i can put everything back together |
8th Nov 2024 10:47am |
Right just checked myself and guess what …..yes the fault still there(thanks wife) this is the error code from gap
8th Nov 2024 1:53pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35434 |
i think you said in one of your many other posts that you've only had this FF for a few months so why not take it back to the dealer that sold it to you... ... - .- -.
8th Nov 2024 2:11pm |
lol i would if they weren’t 400 miles away , i think it’s something simple/silly and i can’t see it for looking at it …..i may have to take to a indy who i know …….just don’t like to be beat . what im not sure of is it the parking sensors causing the problem and the park assist it’s just an out come |
8th Nov 2024 2:46pm |
Park assist will only operate if you have the parking sensor system up and running, I had one faulty sensor on the front outer that shutdown the entire front, side and rear parking aid and the park assist system (as park assist uses the front, rear and side sensors). I'm sure if you solve the Parking aid issue you will find that the park assist works.
8th Nov 2024 2:54pm |
thanks for confirming my thinking (parking sensors causing) i have already emailed patrick at gap so just waiting on a reply i do have 3 sensors with paint worn off and look a bit rubbish may have to get them replaced and see what happens gap tool isn’t telling me anything about sensors |
8th Nov 2024 3:03pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1248 |
I guess you are not one for reading the WSM .
8th Nov 2024 6:13pm |
i did have a read but because i was getting error codes when i checked with gap tool didnt think i could do anything |
8th Nov 2024 6:35pm |
do you mean ccf relearn ? |
8th Nov 2024 8:14pm |
