![]() | Home > Technical (L322) > No HVAC fans, Final stage resistor removed |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
is there a separate fuse for the resister? |
Marksman Member Since: 24 Dec 2010 Location: Durham Posts: 73 ![]() ![]() ![]() |
I have removed fuses 12, 25 , 61 and 64 (all those that feed the blower motor and the HVAC control module) left them out for 30 mins refitted with no benefit.
that's the strange about the range, one minute all the dash lights are lighting up then next day everything is back to normal..
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 ![]() ![]() ![]() |
Did you get to the bottom of this ? As my blower has stopped working also ?
When was your pollen filter last changed?
My Pollen filter was changed in July 2010 so should be fine, I recently did my rocker cover and so had the pollen filter off, so I should remove again and have a feel if anything has dropped down.
If you look through the two holes you will see the fan.
My fan / blower is the cause, if you remove the intake and spin the fan (with the power off / key out) you may be lucky and it will work, mine has so far but occassionally makes a squeek so will need looking at £1100 |
Yeh, I will have to look at this on Thursday when I'm off, have read that it could be the FSR, which I replaced 3 years ago, but I am aware i had some squeaking/dry noises from my fan on several occasions and then went.
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
If the fan motor has died, I would suggest that rather than paying £1100 for a replacement, your local alternator repair place (look in yellow pages) would be able to rewind the motor coils for not very much (I would expect less than £100) - not much else to go wrong ... |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Its the getting it out and putting it back that costs the money. You have to remove the whole dash top get at it ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Just a little feedback for you, I took my pollen filter cover out yesterday had a feel of my blow fan blades which moved ok, then I put ignition on started blowers and they work |
Happy days! Another problem bites the dust! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/] 04, 4.4V8, Vogue Oslo Blue with LPG. "You can sleep in your car, BUT you can't race your house!!!!" If something can't be fixed with a hammer....... You have yourself an electrical fault! |
