Home > Technical (L322) > No HVAC fans, Final stage resistor removed |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 |
I hope so, or another problem is lurking, but that would be negative.
13th Sep 2011 5:13pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
Fuse 34? 7.5A |
12th Mar 2012 6:17pm |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 |
Tried fuse 34 to no avail
12th Mar 2012 7:32pm |
What I would do is test the motor as follows.
12th Mar 2012 8:25pm |
No luck
15th Mar 2012 5:43pm |
UPDATE: Half a year later...
13th Oct 2012 6:12pm |
If you still have the FSR you took out as being faulty you could try refitting it in place of the "new one" and see what happens. |
13th Oct 2012 6:59pm |
Replaced the FSR with the old one just now, everything worked as it should again,, speed control and all.
14th Oct 2012 11:56am |
Interesting.
14th Oct 2012 1:41pm |
I don't think it's a dodgy connection as it would stop, start and work at the desired speed before I took the key out. Key back-in 2min later and it's back to how it was.
14th Oct 2012 2:35pm |
As long as you are satisfied it's not a bad connection I would put the "new FSR" back in. Set the speed control knob to max and switch on the ign and see what happens. |
14th Oct 2012 3:23pm |
No luck, I've tried full speed before ignition on. Check all fuses and checked the FSR connection. The FSR is slightly warm so it's receiving power and I know the fan works along with the controls.
16th Oct 2012 2:14pm |
Could of course be a faulty rotary fan speed selector switch.
16th Oct 2012 4:25pm |
I don't want to be one of these people who leave this thread without an ending, I know there will be people finding this on google by looking for solutions to their own problems
16th Feb 2013 12:21am |
