Home > Technical (L322) > No HVAC fans, Final stage resistor removed
Marksman
I don't have any front ventilation / air con fans ???? the lights around the control knob illuminate when I turn it up and down but no fans, I have replaced the final stage resitor unit (hedgehog) with a new unit and it's still the same ? I even tried a second FSR just in case, I have it booked in to my independant landi specialists tomorrow to see what the diagnostics show if anything, anyone got any ideas ? Question Question
Post #76736 19th Aug 2011 2:45pm
is there a separate fuse for the resister?
Post #76737 19th Aug 2011 2:50pm
Marksman
I have removed fuses 12, 25 , 61 and 64 (all those that feed the blower motor and the HVAC control module) left them out for 30 mins refitted with no benefit.
Landrover specialist today said £1100 for new blower motor ?? but when driving away the blowers working fine ?
Post #76823 20th Aug 2011 8:56am
that's the strange about the range, one minute all the dash lights are lighting up then next day everything is back to normal..
possibly a loose connection from when you fitted the resistor is now ok..
Post #76825 20th Aug 2011 9:27am
swast4
Did you get to the bottom of this ? As my blower has stopped working also ?
Adam
Post #78279 30th Aug 2011 3:24pm
dan_uk_1984
When was your pollen filter last changed?
In the P38, if they werent changed they blocked the air flow, then the motors overheated.
It is also possible that the filter has dissintegrated and is jamming the motor... This is easy to check. You can take the whole intake out with just two nuts:
Post #78281 30th Aug 2011 3:27pm
swast4
My Pollen filter was changed in July 2010 so should be fine, I recently did my rocker cover and so had the pollen filter off, so I should remove again and have a feel if anything has dropped down.
I don't surpose anyone knows where fan is located ? I presume remove the side cover under glove box or opposite side under steering wheel ?
Adam
Post #78282 30th Aug 2011 3:31pm
dan_uk_1984
If you look through the two holes you will see the fan.
It's a dash out job to replace (the entire dash!)
Looks like this:
Post #78283 30th Aug 2011 3:35pm
swast4
Confused I serverly hope its not the fan, that would be a massive ball ache !
I will investigat further tomorrow.
Adam
Post #78295 30th Aug 2011 4:58pm
Marksman
My fan / blower is the cause, if you remove the intake and spin the fan (with the power off / key out) you may be lucky and it will work, mine has so far but occassionally makes a squeek so will need looking at £1100 Sad
Post #78983 3rd Sep 2011 1:19pm
swast4
Yeh, I will have to look at this on Thursday when I'm off, have read that it could be the FSR, which I replaced 3 years ago, but I am aware i had some squeaking/dry noises from my fan on several occasions and then went.
Ideally I should take fan out and see if it is servicable but sounds like a ball ache to get to it. Anyway fingers crossed.
Adam
Post #80381 11th Sep 2011 12:32pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
If the fan motor has died, I would suggest that rather than paying £1100 for a replacement, your local alternator repair place (look in yellow pages) would be able to rewind the motor coils for not very much (I would expect less than £100) - not much else to go wrong ...
Post #80547 12th Sep 2011 10:46am
Its the getting it out and putting it back that costs the money. You have to remove the whole dash top get at it Big Cry .
Post #80570 12th Sep 2011 11:35am
swast4
Just a little feedback for you, I took my pollen filter cover out yesterday had a feel of my blow fan blades which moved ok, then I put ignition on started blowers and they work Bow down so they must have been sticky. I had some V belt spray, which I think is an alcohol based type cleaner (from tool station) and easily evaporates and sprayed this into the blower area when not running then when running. Seems to be working fine so fingers crossed Whistle
Adam
Post #80885 13th Sep 2011 1:43pm
Adam
Happy days! Another problem bites the dust! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #80895 13th Sep 2011 2:35pm
