Home > Maintenance & Mods (L405) > Is this an easy fix or should I not bother? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3813 |
Drivers window switch doesn't light uo.
17th Jul 2024 11:16pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35343 |
at least you can see which is the drivers window switch at night.. ... - .- -.
18th Jul 2024 7:19am |
bigdave Site Sponsor Member Since: 27 Jun 2011 Location: Cornwall Posts: 205 |
All things transport - big or small, UK or planetwide.
18th Jul 2024 7:53am |
Thanks all - it's not a simple job or a cheap fix so I won't be doing it. I can't think of the last time I opened the drivers window or any window in fact at night and as Stan says its pretty obvious where the switch is if I ever need to, although I can't think when that will be Geoff |
18th Jul 2024 8:18am |
probably a night visit to a drive thru mcd's Geoff... ... - .- -.
18th Jul 2024 9:28am |
I take your point Stan, although If I'm sneaking off to the drive through at night it would be KFC McDonalds is for breakfast Geoff |
18th Jul 2024 10:03am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1375 |
Funnily enough, my drivers switch button is exactly the same in that it’s gone out.
18th Jul 2024 10:35am |
Thinking outside the box here, could it be an indication that the "one" close is activated or not on that particular switch... ... - .- -.
18th Jul 2024 11:05am |
I ll double check but I think my one close works on all windows at the moment … I know I can one close / open the windows using the key fob and that wouldn’t happen if one close wasn’t set properly I presume. V8 or else ... |
19th Jul 2024 9:31am |
