Home > Maintenance & Mods (L405) > Is this an easy fix or should I not bother?
supershuttle
Drivers window switch doesn't light uo.
 Geoff
Post #696413 17th Jul 2024 11:16pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
The illumination is from LEDs on the circuit board under the buttons, they can be replaced but need very good soldering skills assuming you can find replacements.
The easiest if not cheapest solution is to replace the entire switch module after removing the door card.
If you can live with it, wait until enough LEDs have failed to make it worthwhile replacing the unit.
Post #696417 18th Jul 2024 6:53am
at least you can see which is the drivers window switch at night.. Thumbs Up ... - .- -.
Post #696420 18th Jul 2024 7:19am
bigdave
Site Sponsor
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
Thumbs Up Thumbs Up All things transport - big or small, UK or planetwide.
E-mail info@md-couriers.co.uk
Post #696422 18th Jul 2024 7:53am
supershuttle
Thanks all - it's not a simple job or a cheap fix so I won't be doing it. I can't think of the last time I opened the drivers window or any window in fact at night and as Stan says its pretty obvious where the switch is if I ever need to, although I can't think when that will be Rolling with laughter Geoff
Post #696424 18th Jul 2024 8:18am
probably a night visit to a drive thru mcd's Geoff... ... - .- -.
Post #696429 18th Jul 2024 9:28am
supershuttle
I take your point Stan, although If I'm sneaking off to the drive through at night it would be KFC Thumbs Up McDonalds is for breakfast Thumbs Up Geoff
Post #696434 18th Jul 2024 10:03am
fisha
Funnily enough, my drivers switch button is exactly the same in that it’s gone out.
Too much hassle to fix for all the time I look at it. V8 or else ...
Post #696436 18th Jul 2024 10:35am
Thinking outside the box here, could it be an indication that the "one" close is activated or not on that particular switch... ... - .- -.
Post #696438 18th Jul 2024 11:05am
fisha
I ll double check but I think my one close works on all windows at the moment … I know I can one close / open the windows using the key fob and that wouldn’t happen if one close wasn’t set properly I presume. V8 or else ...
Post #696488 19th Jul 2024 9:31am
