![]() | Home > Maintenance & Mods (L405) > Is this an easy fix or should I not bother? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3895 ![]() ![]() ![]() |
Drivers window switch doesn't light uo.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35644 ![]() ![]() |
at least you can see which is the drivers window switch at night.. |
bigdave Site Sponsor Member Since: 27 Jun 2011 Location: Cornwall Posts: 221 ![]() ![]() ![]() |
Thanks all - it's not a simple job or a cheap fix so I won't be doing it. I can't think of the last time I opened the drivers window or any window in fact at night and as Stan says its pretty obvious where the switch is if I ever need to, although I can't think when that will be |
probably a night visit to a drive thru mcd's Geoff... ... - .- -.
I take your point Stan, although If I'm sneaking off to the drive through at night it would be KFC |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1462 ![]() ![]() |
Funnily enough, my drivers switch button is exactly the same in that it’s gone out.
Thinking outside the box here, could it be an indication that the "one" close is activated or not on that particular switch... ... - .- -.
I ll double check but I think my one close works on all windows at the moment … I know I can one close / open the windows using the key fob and that wouldn’t happen if one close wasn’t set properly I presume. V8 or else ... |
