Home > Technical (L322) > Front suspension strut confusion
Squirrel
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Galway Green
I had my n/s front suspension airbag and strut replaced 1000 miles ago due to a suspension fault.
A couple of days ago, my car started displaying an Adaptive Dynamics fault. I thought (hoped!) it would be the common wiring fault, so I took it in today. The mechanic is now saying it's the n/s front strut that's failed. It's reporting an open circuit on the diagnostics.
So I'm just wondering. What are the chances of an aftermarket part failing after just 1000 miles? I suppose any part can fail soon after fitting. But what are the chances of it simply being the wiring at fault? The OBD reader could work that one out, couldn't it?
Either way, I don't much fancy paying another £1700+ for a repair I had done five minutes ago. So any and all advice would be gratefully received - thank you!
Post #690214 8th Apr 2024 11:21am
GraemeS
Australia
Is the damper a real CVD or is it the brand that has a dummy sitting on top of a non-CVD damper?
Post #690215 8th Apr 2024 11:26am
Squirrel
I have no idea - how can I tell?
Post #690217 8th Apr 2024 11:34am
mjdronfield
What make of shocker got fitted?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #690219 8th Apr 2024 11:51am
JayGee
£1700 to replace a front strut.......... Censored
If they supplied the strut it should be replaced free of charge if it's failed. 2012 TDV8 Vogue (L322)
Post #690236 8th Apr 2024 1:37pm
Squirrel
I don't remember - it was an aftermarket part.
Yeah, the £1700 is for one hour's labour - the rest is the cost of the part. Almost £1300 + VAT! THe garage has said I shouldn't get aftermarket struts because they don't last, but I'd expect them to last more than 1000 miles!
I bet they'll have some kind of clause that says no offroading. My car hasn't been offroading, but how do I prove that?
Post #690241 8th Apr 2024 2:42pm
mjdronfield
That seems a mad thing to say no off-roading…. If that’s what they do say. The whole car is designed as an off roader, and you fitted a genuine strut too…..
I’d say they have to prove you did, not you proving you didn’t…..
I’d be wanting a better brake down of the bill if it was £1700……
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #690243 8th Apr 2024 2:54pm
mjdronfield
Seems genuine part is about £600
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #690244 8th Apr 2024 3:04pm
Squirrel
I've looked at the company's Ts and Cs - they don't specifically mention offroading. But they do say they won't cover the cost of labour to remove and refit a faulty part. Censored .
I've just got one for £725 + VAT - stock seems to be limited!
Post #690257 8th Apr 2024 5:51pm
JayGee
If the garage supplied the part and it failed in such a short time they should fit a replacement part free of charge - consumer law will be on your side. 2012 TDV8 Vogue (L322)
Post #690258 8th Apr 2024 5:54pm
Squirrel
The supplier has said they'll replace the part if they test it and deem it to be faulty, but they won't pay for labour. So I should go after the garage that fitted it to get them to replace it for free?
I'm not sure I want to do that. I can't afford to chuck away money, but I know my mechanic hasn't even paid himself a salary for the past couple of months. Crying or Very sad
Post #690315 9th Apr 2024 3:20pm
JayGee
Please clarify - you bought the strut and gave it to the garage to fit or did you pay the garage to supply and fit the strut? 2012 TDV8 Vogue (L322)
Post #690316 9th Apr 2024 3:29pm
mjdronfield
Well, you know more than you did before this thread started, eg the genuine part is nowhere near what you have been charged, you could have got 2…. And the part should not have failed in that short time, if indeed you are sure it’s actually faulty. Difficult one. I’d still be wanting a proper break down of the £1700 given the parts cost…. Unless we have misunderstood it…
You need to get to where you are happy and the car is working without errors… with minimum further expenditure…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #690317 9th Apr 2024 3:34pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
So I'm confused here.
Did the garage supply the part?
What brand strut was fitted?
How much was the part? And the labour?
Labour wise, the saving grace is that if the garage have only recently replaced the strut, replacing it again shouldn't take more than half an hour as the fixtures will all be easily removed. Other than the lower bolts into the knuckle which are often seized, there's not much difficulty to the job and on a lift it's dead easy to do - remove top weight, one wiring connector, three nuts at the top, one airline connection, one nut on the ARB droplink, couple of clips to undo, and the two knuckle bolts. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #690318 9th Apr 2024 3:36pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
https://www.fullfatrr.com/forum/topic67977.html
Post #690320 9th Apr 2024 4:00pm
