![]() | Home > Technical (L322) > Front suspension strut confusion |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2651 ![]() ![]() |
Is the damper a real CVD or is it the brand that has a dummy sitting on top of a non-CVD damper? |
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212 ![]() ![]() ![]() |
I have no idea - how can I tell? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7911 ![]() ![]() ![]() |
What make of shocker got fitted?
£1700 to replace a front strut.......... |
I don't remember - it was an aftermarket part. Yeah, the £1700 is for one hour's labour - the rest is the cost of the part. Almost £1300 + VAT! THe garage has said I shouldn't get aftermarket struts because they don't last, but I'd expect them to last more than 1000 miles! I bet they'll have some kind of clause that says no offroading. My car hasn't been offroading, but how do I prove that? |
That seems a mad thing to say no off-roading…. If that’s what they do say. The whole car is designed as an off roader, and you fitted a genuine strut too…..
Seems genuine part is about £600
Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
I've looked at the company's Ts and Cs - they don't specifically mention offroading. But they do say they won't cover the cost of labour to remove and refit a faulty part. |
If the garage supplied the part and it failed in such a short time they should fit a replacement part free of charge - consumer law will be on your side. 2012 TDV8 Vogue (L322) |
The supplier has said they'll replace the part if they test it and deem it to be faulty, but they won't pay for labour. So I should go after the garage that fitted it to get them to replace it for free?
Please clarify - you bought the strut and gave it to the garage to fit or did you pay the garage to supply and fit the strut? 2012 TDV8 Vogue (L322) |
Well, you know more than you did before this thread started, eg the genuine part is nowhere near what you have been charged, you could have got 2…. And the part should not have failed in that short time, if indeed you are sure it’s actually faulty. Difficult one. I’d still be wanting a proper break down of the £1700 given the parts cost…. Unless we have misunderstood it…
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
So I'm confused here. Did the garage supply the part? What brand strut was fitted? How much was the part? And the labour? Labour wise, the saving grace is that if the garage have only recently replaced the strut, replacing it again shouldn't take more than half an hour as the fixtures will all be easily removed. Other than the lower bolts into the knuckle which are often seized, there's not much difficulty to the job and on a lift it's dead easy to do - remove top weight, one wiring connector, three nuts at the top, one airline connection, one nut on the ARB droplink, couple of clips to undo, and the two knuckle bolts. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 166 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic67977.html |
