Squirrel
Danb_220_2019 wrote:
Did the garage supply the part?
What brand strut was fitted?
How much was the part? And the labour?
Labour wise, the saving grace is that if the garage have only recently replaced the strut, replacing it again shouldn't take more than half an hour as the fixtures will all be easily removed. Other than the lower bolts into the knuckle which are often seized, there's not much difficulty to the job and on a lift it's dead easy to do - remove top weight, one wiring connector, three nuts at the top, one airline connection, one nut on the ARB droplink, couple of clips to undo, and the two knuckle bolts.
Yes. the garage supplied the strut. It cost about £695, if I remember correctly, can't remember what make it was now.
It's good to know it should be relatively easy to replace the strut now that everything has been removed not long ago. Let's hope all the water I've been driving through recently hasn't welded the nuts together!
10th Apr 2024 3:32pm |
