Home > Technical (L322) > V8 5.0 S/C Water Leak, Camchain Tensioners - Symposer Delete
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
Close on 2 years ownership of my 5.0 S/C
Always intended on "visiting" the camchain tensioner and guides (96,000mile)
Well after a 70p O ring caused a £600 worth of parts water leak I thought “while I am here I suppose now is the time” - coolant leak was from alloy pipe O ring behind oil filter housing
Camchain assembly now held together with zip ties till I get new tensioners
Guides are in great condition and like the tensioners are the later style
Old tensioners are very weak and not much life left in them - they didn’t even spring out when I released them !
Oh and Range Rover say “it can’t be done with zip ties”
Well we will soon see once I eventually start it up
What’s the worse that can happen - lol lol
 2009 - L322 5.0 S/C Autobiography
Post #688822 23rd Mar 2024 6:35pm
gt40
South Africa 2011 Range Rover Vogue SE TDV8 Zambezi Silver
The person who stated that obviously didn't get the memo. There is a published Jaguar Land Rover procedure using zip ties to secure the chains while replacing guides and tensioners. Its a bit different to what you have done but it uses zip ties (called tie straps in the manual).
Post #688838 24th Mar 2024 1:13am
RS2000CUSTOM
Yep I did say to the "Tech" that the Repair Procedure was available using zip-ties
As I already have the updated guides fitted I slightly modified the procedure and haven't removed the cam wheel covers 2009 - L322 5.0 S/C Autobiography
Post #688840 24th Mar 2024 6:44am
RS2000CUSTOM
Any part No Guru’s on here ??
My part number cast into the tensioners is
FX23 6K254 AA
I understand how Ford/JLR usually identify updated parts by the last letter
My question is a FX23 6K264 AB the latest spec tensioner ?
Also known as LR095472
Thanks in advance ! 2009 - L322 5.0 S/C Autobiography
Post #688885 24th Mar 2024 3:03pm
gt40
Have you seen the AB suffix on any tensioners?
The last tensioners I replaced were around 6 months ago, purchased from the dealer - they had the AA suffix and I have not heard of any newer revisions.
Post #688923 25th Mar 2024 6:41am
RS2000CUSTOM
Yes AB is the tensioners I am looking at
Post #688925 25th Mar 2024 7:33am
RS2000CUSTOM
Have just ordered Tensioners etc from JLR
They have confirmed that AB are the latest spec 2009 - L322 5.0 S/C Autobiography
Post #688934 25th Mar 2024 9:46am
RS2000CUSTOM
Collected the new Tensioners today and they are AB suffix indicating the latest update versions available
Post #689071 26th Mar 2024 5:44pm
RS2000CUSTOM
What a most satisfying sound !!
Pull the pin and CLICK out shot the plunger
Old tensioner is on bench and will not extend as it stuck in now after I “reset” it - lol
Let the rebuilding begin tomorrow
Post #689238 28th Mar 2024 3:46pm
dhallworth
When I was doing mine, someone in America who has a lot of experience rebuilding these told me to use a big screwdriver and gently lift the guide off the tensioner until you hear another click or two. He says he’s seen them skip a tooth when starting if you don’t.
There’s no mention of it in the manual so make of it what you will Smile
I did it on mine and haven’t had any issues in 6000 miles.
The tensioners that I bought from Duckworth’s in September last year were the AB version too.
Post #689276 28th Mar 2024 9:05pm
RS2000CUSTOM
David.
The amount of pre-tension I had applied to the zip ties I doubt there was any slack left for the tensioner take-up
I understand what was meant by the screwdriver but a slight crank rotation clockwise after fitting tensioner will also put any remaining slack into the tensioner side and I am more than happy it gonna go brum brum once I try to start it - unless it all falls off - lol lol lol 2009 - L322 5.0 S/C Autobiography
Post #689287 28th Mar 2024 11:16pm
RS2000CUSTOM
2nd tensioner replaced
The old tensioner had a lot more tension then the other one
New crank seal fitted and crank pulley back on
Just need to torque crank bolt without moving crank anti-clockwise at all
Post #689361 29th Mar 2024 6:44pm
RS2000CUSTOM
Good job I know a mate with a laser cutter
Made me some blanking plates
Symposer delete before Supercharger goes back on
Did an oil change and coupler replace also on the S/C
All going back together nicely - may even go for an engine start soon 😱 💥
Post #689454 30th Mar 2024 8:41pm
dhallworth
That’s interesting…
My 2012 doesn’t have a symposer. I read somewhere that only the Sports had it so interesting that your car is fitted with it.
Post #689467 31st Mar 2024 1:00am
RS2000CUSTOM
Not sure why fitted to mine but certainly looked “factory”
Here is a pic of vac pipe Y piece going across engine to actuator on symposer
Thankfully it is no more
Post #689498 31st Mar 2024 12:01pm
