Home > Technical (L322) > V8 5.0 S/C Water Leak, Camchain Tensioners - Symposer Delete |
gt40 Member Since: 29 Jan 2013 Location: Cape Town Posts: 31 |
The person who stated that obviously didn't get the memo. There is a published Jaguar Land Rover procedure using zip ties to secure the chains while replacing guides and tensioners. Its a bit different to what you have done but it uses zip ties (called tie straps in the manual). |
24th Mar 2024 1:13am |
RS2000CUSTOM Member Since: 25 Apr 2013 Location: The Black Country Posts: 137 |
Yep I did say to the "Tech" that the Repair Procedure was available using zip-ties As I already have the updated guides fitted I slightly modified the procedure and haven't removed the cam wheel covers 2009 - L322 5.0 S/C Autobiography |
24th Mar 2024 6:44am |
Any part No Guru’s on here ??
24th Mar 2024 3:03pm |
Have you seen the AB suffix on any tensioners?
25th Mar 2024 6:41am |
Yes AB is the tensioners I am looking at
25th Mar 2024 7:33am |
Have just ordered Tensioners etc from JLR They have confirmed that AB are the latest spec 2009 - L322 5.0 S/C Autobiography |
25th Mar 2024 9:46am |
Collected the new Tensioners today and they are AB suffix indicating the latest update versions available
26th Mar 2024 5:44pm |
What a most satisfying sound !!
28th Mar 2024 3:46pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3137 |
When I was doing mine, someone in America who has a lot of experience rebuilding these told me to use a big screwdriver and gently lift the guide off the tensioner until you hear another click or two. He says he’s seen them skip a tooth when starting if you don’t.
28th Mar 2024 9:05pm |
The amount of pre-tension I had applied to the zip ties I doubt there was any slack left for the tensioner take-up I understand what was meant by the screwdriver but a slight crank rotation clockwise after fitting tensioner will also put any remaining slack into the tensioner side and I am more than happy it gonna go brum brum once I try to start it - unless it all falls off - lol lol lol 2009 - L322 5.0 S/C Autobiography |
28th Mar 2024 11:16pm |
2nd tensioner replaced
29th Mar 2024 6:44pm |
Good job I know a mate with a laser cutter
30th Mar 2024 8:41pm |
That’s interesting…
31st Mar 2024 1:00am |
Not sure why fitted to mine but certainly looked “factory”
31st Mar 2024 12:01pm |
