![]() | Home > Technical (L322) > V8 5.0 S/C Water Leak, Camchain Tensioners - Symposer Delete |
gt40 Member Since: 29 Jan 2013 Location: Cape Town Posts: 31 ![]() ![]() ![]() |
The person who stated that obviously didn't get the memo. There is a published Jaguar Land Rover procedure using zip ties to secure the chains while replacing guides and tensioners. Its a bit different to what you have done but it uses zip ties (called tie straps in the manual). |
RS2000CUSTOM Member Since: 25 Apr 2013 Location: The Black Country Posts: 137 ![]() ![]() ![]() |
Yep I did say to the "Tech" that the Repair Procedure was available using zip-ties As I already have the updated guides fitted I slightly modified the procedure and haven't removed the cam wheel covers 2009 - L322 5.0 S/C Autobiography |
Any part No Guru’s on here ??
Have you seen the AB suffix on any tensioners?
Yes AB is the tensioners I am looking at
Have just ordered Tensioners etc from JLR They have confirmed that AB are the latest spec 2009 - L322 5.0 S/C Autobiography |
Collected the new Tensioners today and they are AB suffix indicating the latest update versions available
What a most satisfying sound !!
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
When I was doing mine, someone in America who has a lot of experience rebuilding these told me to use a big screwdriver and gently lift the guide off the tensioner until you hear another click or two. He says he’s seen them skip a tooth when starting if you don’t.
The amount of pre-tension I had applied to the zip ties I doubt there was any slack left for the tensioner take-up I understand what was meant by the screwdriver but a slight crank rotation clockwise after fitting tensioner will also put any remaining slack into the tensioner side and I am more than happy it gonna go brum brum once I try to start it - unless it all falls off - lol lol lol 2009 - L322 5.0 S/C Autobiography |
2nd tensioner replaced
Good job I know a mate with a laser cutter
That’s interesting…
Not sure why fitted to mine but certainly looked “factory”
