Home > Technical (L322) > V8 5.0 S/C Water Leak, Camchain Tensioners - Symposer Delete
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
Well the zip-ties are off and it's ALIVE !
Started with no issues or gremlins - coolant system bled with no problem
Let the engine get up to temperature with eyes on storks looking for leaks etc
Thankfully all good
So after a few days work it now appears sorted
My little check list :
Oil
Oil Filter
2 x Air filters
8 x spark plugs
8 x coil packs
Water pump
Anti-freeze
oil cooler gasket
2 x inlet manifold gaskets
Supercharger gasket
Supercharger oil change
Supercharger Coupler replace
Throttle body gasket
4 x front Y piece O rings
Alt belt
Superseded water pump bypass hose kit
Front crank seal
2 x updated camchain tensioners
Symposer delete
 2009 - L322 5.0 S/C Autobiography
Post #689528 31st Mar 2024 4:13pm
dhallworth
Nicely done Smile
It’s a time consuming job but it’s not difficult. Hope it continues to behave for you.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #689543 31st Mar 2024 6:55pm
RS2000CUSTOM
Well nearly 3 weeks on and still all good
Only 1 issue !
1 TPMS lock nut failed and fell off
And 2nd TPMS lock nut split and about to fail
So fitted 4 new TPMS valves and sorted
Always something on a Range Rover to spend money on 😳
Post #690733 16th Apr 2024 1:54pm
RS2000CUSTOM
dhallworth wrote:
Nicely done Smile
David.
Just glad I was able to all the jobs myself as I wouldnt want to pay a Main Dealer labour rate for all the hours I spent on doing everything 2009 - L322 5.0 S/C Autobiography
Post #690735 16th Apr 2024 1:56pm
