Home > Technical (L405) > front knuckle cracking |
portrobc Member Since: 17 Mar 2017 Location: Evesham Posts: 63 |
@ Fisha........Just spoken to the local main dealer.....they know of the issue but not the detail. Are investigating the way forward and will get back to me.
17th Aug 2023 8:52am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1400 |
I think you're right, its going to take time to get the parts into dealers / sort out the process. The same was true for the BMW and its EGR recall ... parts supply was the delay as there were so many. Quick check of mine shows no cracks at the moment. V8 or else ... |
17th Aug 2023 9:00am |
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 135 |
Sorry for the dumb question of the day, but if i dont have topix access - how do i access the online service history to check my car?
17th Aug 2023 9:23am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35439 |
put your vin number in here,
17th Aug 2023 9:27am |
Thanks Stan
17th Aug 2023 9:37am |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 130 |
Land rover are saying its a bad batch of knuckles and if the batch number stamped on the knuckle is between G048840 and G058314 then they need to be replaced. As they have now admited the problem i think its time for all those who have had to cover the cost to replace the knuckles when they failed to dig out the paperwork and get on the phone to Landrover customer Services for a refund but also check to make sure that the new knuckles that were fitted do no fall within the bad batch number. |
17th Aug 2023 9:53am |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 230 |
Whilst this is a start, I would hope the VIN range is expanded over time as we have now seen later vehicles affected (at least two 2018 vehicles https://www.fullfatrr.com/forum/topic66376.html)
17th Aug 2023 10:43am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2586 |
What’s the consensus on cause? Fatigue? Corrosion? Over-tightened from new? |
17th Aug 2023 1:46pm |
faulty casting ? ... - .- -.
17th Aug 2023 3:02pm |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 742 |
Well done to all those people who put pressure on LR and VOSA to get this recall underway in the UK. 2021 P400 Silicon Silver AB
17th Aug 2023 3:49pm |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 189 |
Mines booked into pentlands on 5 September. Apparently it’s 2 hours to check for cracks. Also asked about parts. At the moment at least the parts are available. I think they will run out rather quickly 2016 4.4 diesel |
17th Aug 2023 7:04pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 902 |
I wonder how they will carry out the inspection?
17th Aug 2023 7:21pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3785 |
Try Googling “ crack detection spray “
17th Aug 2023 8:24pm |
UPDATE...........Spoken to Main Dealer all booked in, 2 stage process apparently.....inspection first to identify if there is a problem and then a rebook appointment as a priority to get any remedial work done if it is needed. To be fair they were very accommodating which is a good sign. HTH Rob Now running a 2016 Autobiography plus a Bentley Continental GTC Previously ran a Lincoln Navigator and 18 XC60 T5 Before that a pile of Jeeps, Mercedes and Jaguars and Porsches, Mustang and Volvo. |
18th Aug 2023 7:53am |
