![]() | Home > Technical (L405) > front knuckle cracking |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
I have started to clean mine up with some ACF50 every time it’s on the ramp to check for this after the other thread.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 475 ![]() ![]() ![]() |
Still waiting for the part to arrive, they’re on back order and the estimated date for delivery is 26/01/23.
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 395 ![]() ![]() ![]() |
Interesting that Canada have seemingly started to recall cars affected by this problem. I wonder if anything will happen here in the UK?
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 287 ![]() ![]() ![]() |
Zebedee - very interesting and thanks for posting. I’m interested to see that it covers 2016 MY as I had thought that up to 2015 was the cutoff for the relevant VINs. Watching with interest… 2016 SDV8 AB |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1664 ![]() ![]() ![]() |
I thought I would have a bash... just sent this email to LR along with my VIN, address and mobile number. I'll update if I get a reply.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1810 ![]() ![]() |
Oddly, N759 isn't an outstanding recall yet |
v.confusing given the letter posted above.
lee.norg Member Since: 23 Aug 2022 Location: Manchester Posts: 15 ![]() ![]() ![]() |
I was arriving at my parent's place over the weekend and upon reversing outside of their house felt a clunk then the car went into extended suspension mode and something didn't feel quite right. Upon checking the car the front passenger wheel was not straight and i realised how lucky i was, with this happening outside of their house rather than 70 miles per hour on the motorway. Has anyone had this situation happen in the past? with the top of the hub snapping? It looks like a new hub, and boot for my air suspension strut is needed and luckily no further damage that i can see.
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
You're not alone. This same issue has been documented a number of times on this forum and beyond. Have a quick search of the forum as there's an extensive thread about similar failures.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
As op check this out.https://www.fullfatrr.com/forum/topic55957.html?highlight=catastrophic+suspension
blackbeltbob Member Since: 06 Oct 2022 Location: Ayrshire Posts: 32 ![]() ![]() ![]() |
deleted as i was waaayy too slow pressing reply |
Link above in post #2 to previous thread on this subject. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Thanks all, I'll take a look. Just a big surprise something like this has happened with no prior warning 2016 Range Rover L405 4.4 SDV8 Autobiography |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Need a lawyer to get his teeth into this issue.
