Home > Technical (L322) > 4.4tdv8 oil light
Page 1 of 3 123>
Daitdv8
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
4.4tdv8 oil light
Hello all
New to the forum and I'm looking for a little help.
Have searched and I can only find one thread with similar problems but I didn't get any information on the where abouts of the oil pressure sensor.
I've got a 4.4 tdv8 range rover, I'm getting the oil light flash up for not even a second only on first start of the day.
I've changed the oil and filter, where are the oil pressure sensors on these?
Thanks
Post #667555 25th Jun 2023 8:22pm
garyRR
Good news is it's right at the top and front of the engine by the auxiliary belt, above the upper left pulley (as seen facing the engine bay).
As you're new to the forum, if you visit the 'Wiki' section, there's a link to download the complete workshop manual for the 4.4 TDV8.
There's also a link to the parts catalogues to get part numbers.
I haven't read about anyone having this issue though, so be prepared for it to be something else, such as the battery on its way out or the oil level sensor.
Hope this helps. 2015 Range Rover Autobiography 4.4 SDV8
Post #667563 25th Jun 2023 9:29pm
Daitdv8
Hello
Thank you for the swift reply, I'm using my mobile and can't seem to find the file or part numbers
Could the level sensor cause that sort of issue?
Post #667564 25th Jun 2023 9:47pm
JayGee
I get low oil pressure on cold startup if I park on a steep uphill slope. It's not a sensor fault as it never happens on the level. 2012 TDV8 Vogue (L322)
Post #667576 26th Jun 2023 6:48am
Daitdv8
Thats how mine started, now doing it on level too.
Post #667577 26th Jun 2023 6:50am
JayGee
How many miles on your engine? 2012 TDV8 Vogue (L322)
Post #667581 26th Jun 2023 7:31am
Daitdv8
108k
It will be a sensor issue, just not sure if it's the level sensor or pressure sensor
Post #667595 26th Jun 2023 12:33pm
JayGee
AFAIK the level sensor displays a low oil text info on the dash. The 'oil can' light on the instrument is low pressure. 2012 TDV8 Vogue (L322)
Post #667598 26th Jun 2023 12:45pm
garyRR
If of any assistance, the oil level sensor is on the bottom of the sump (I saw it today whilst changing the diff oils).
Very easy to access if needed, but does require an oil drain.
The bolts on my one aren't corroded, so it looks like mine may have been changed at some point. 2015 Range Rover Autobiography 4.4 SDV8
Post #667616 26th Jun 2023 3:22pm
Daitdv8
Thank you
I'm going to change the sensor, I'm not overly worried but it didn't do it before.
Tested the oil pressure on cold start and its spot on.
Post #667632 26th Jun 2023 6:15pm
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Mine does this too, when parked on level or on incline.
Start car, all other dash lights switch off, oil pressure light flashes for not even a second and never comes on again. I assumed it’s either a momentary lack of pressure whilst pump gets going, or the beginnings of a failing sensor. I’ve not tested oil pressure with an independent gauge but will do so soonish to be certain.
Let me know how you get on with changing the sensor. I assume it’s a relatively simple job and no need to remove any other parts to access the sensor. Are any special tools required? Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration!
Post #667650 26th Jun 2023 8:23pm
JayGee
On a slope mine comes on a few seconds after starting and lasts quite a few seconds accompanied by a definite rattling noise from the engine which stops as soon as the light goes out so I doubt it's the sensor on mine at least. I've had it happen on the level when I drained the oil from cold. I got nearly 1L more out than when doing a hot drain so likley quite a bit of oil is in the upper engine which drains down overnight and it's quite a long way to pump it back up again. Cold starts with thick oil generate max oil pressure but slowest circulation times so I think it's nothing to worry about. I never blip the throttle and always idle for 30 seconds before engaging drive in the mornings. An oil light showing on a hot engine at idle would be a big worry though..... 2012 TDV8 Vogue (L322)
Post #667654 26th Jun 2023 8:38pm
Daitdv8
Just thought I'd update
Oil pressure sensor replaced and no oil light in the morning since, hopefully this helps someone else with a similar problem.
Post #668034 1st Jul 2023 7:46am
mgrover
Mine does same.
Got a part number handy? Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #668149 2nd Jul 2023 4:51pm
Daitdv8
Yes its LR000633
Post #668150 2nd Jul 2023 5:03pm
Page 1 of 3 123>
