![]() | Home > Technical (L322) > 4.4tdv8 oil light |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1481 ![]() ![]() |
Good news is it's right at the top and front of the engine by the auxiliary belt, above the upper left pulley (as seen facing the engine bay).
As you're new to the forum, if you visit the 'Wiki' section, there's a link to download the complete workshop manual for the 4.4 TDV8. There's also a link to the parts catalogues to get part numbers. I haven't read about anyone having this issue though, so be prepared for it to be something else, such as the battery on its way out or the oil level sensor. Hope this helps. 2015 Range Rover Autobiography 4.4 SDV8 |
Daitdv8 Member Since: 25 Jun 2023 Location: Blackwood Posts: 14 ![]() ![]() ![]() |
Hello
I get low oil pressure on cold startup if I park on a steep uphill slope. It's not a sensor fault as it never happens on the level. 2012 TDV8 Vogue (L322) |
Thats how mine started, now doing it on level too. |
How many miles on your engine? 2012 TDV8 Vogue (L322) |
108k
AFAIK the level sensor displays a low oil text info on the dash. The 'oil can' light on the instrument is low pressure. 2012 TDV8 Vogue (L322) |
If of any assistance, the oil level sensor is on the bottom of the sump (I saw it today whilst changing the diff oils).
Thank you I'm going to change the sensor, I'm not overly worried but it didn't do it before. Tested the oil pressure on cold start and its spot on. |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
Mine does this too, when parked on level or on incline.
On a slope mine comes on a few seconds after starting and lasts quite a few seconds accompanied by a definite rattling noise from the engine which stops as soon as the light goes out so I doubt it's the sensor on mine at least. I've had it happen on the level when I drained the oil from cold. I got nearly 1L more out than when doing a hot drain so likley quite a bit of oil is in the upper engine which drains down overnight and it's quite a long way to pump it back up again. Cold starts with thick oil generate max oil pressure but slowest circulation times so I think it's nothing to worry about. I never blip the throttle and always idle for 30 seconds before engaging drive in the mornings. An oil light showing on a hot engine at idle would be a big worry though..... 2012 TDV8 Vogue (L322) |
Just thought I'd update
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
Mine does same.
Yes its LR000633 |
