![]() | Home > Technical (L322) > 4.4tdv8 oil light |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 416 ![]() ![]() ![]() |
Awesome, ordered.
Daitdv8 Member Since: 25 Jun 2023 Location: Blackwood Posts: 14 ![]() ![]() ![]() |
Just the one, to the left as you look at the engine. Make sure its torqued up |
genuinely am struggling to find it ![]() could you take a picture of it in the context of the engine bay when you get a chance please. Its actually a sport ![]() Not anymore, 4.4 TDV8 now ![]() |
Sure
now thats where it may get more worrying and make me start wondering about the oil pump. Its actually a sport |
If its a split second in the morning I wouldn't stress, if it comes on when hot then I'd burn it. |
its always morning and when cold thankfully. Its actually a sport |
Is there an 'anti drain back' valve in the system (oil filter housing?) 2012 TDV8 Vogue (L322) |
I've not actually looked into that |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
Underneath the oil filter is a 'leaf spring' which I think is an anti drain device.
Good bit of info. Never looked down there but will next oil change. 2012 TDV8 Vogue (L322) |
the only thing I can see in that location is something plugged into the vacuum pump, is that normal? Its actually a sport |
It's to the left of the turbo boost solenoid, you'll need to move a few wires to see it. |
Just a thought
