Home > My Range Rover > Back with another Supercharged! A 5.0 this time! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8246 |
David,
3rd Dec 2024 9:36am |
Thinking about it it's got to be the calliper on the discs. If I drive mine a lot on adaptive the rear wheels are covered in brake dust as much as the fronts.... Pete
3rd Dec 2024 9:39am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3106 |
The calipers are nice and free though, it's really weird.
3rd Dec 2024 10:09pm |
Maybe the handbrake is sticking slightly and the extra heat created from the rear braking with cruise isn't helping...!!!
4th Dec 2024 11:00am |
Ordered handbrake cables from the JLR Classic Parts website on Monday afternoon and they’ve just been delivered by DHL.
4th Dec 2024 11:07am |
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 81 |
Maybe check the park brake shoes retaining pins are holding in the backplates properly if it has that setup . Older type pin washers can be fitted on the pins . Kits can be found on eBay and Amazon |
5th Dec 2024 9:14am |
Thanks for the pointer.
5th Dec 2024 9:20am |
Another trick is to partially fold a suitable size washer over the shoe retaining pin if the correct washer is not available. The retaining pin should be orientated to remain secure |
5th Dec 2024 9:45am |
Finally managed to get some time on the Range Rover this weekend after waiting for aaagggeeessss for my parts to arrive.
15th Dec 2024 10:32pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 588 |
I agree with you David, but I found I needed to react quicker than I expected when a tyre delaminated. I had the TPMS flash up a warning on a normal A road at something like 23psi. It was then going down ~2 PSi every second and I had to spot somewhere and get relatively safe off the carriagway in a few seconds. I was lucky and found a wide driveway to change the wheel in but, as I say, just luck that that came up so soon after the warning. Mike - MPx 2017 5.0 V8 Supercharged SVAutobigraphy Dynamic SVO Palette Grey (2021-...) 2012 5.0 V8 Supercharged Autoboigraphy Orkney Grey (2017-2021) 2007 4.2 V8 Supercharged Vogue SE Tonga Green (2012-2017) 2002 4.4 V8 Vogue Bonnatti Grey (2008-2012) |
15th Dec 2024 11:08pm |
Rear callipers went on my S/C, I think it's relatively common.
16th Dec 2024 11:01am |
Car is now rebuilt.
23rd Dec 2024 1:23am |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 901 |
Epic, well done |
23rd Dec 2024 8:44am |
Nice Christmas present for it.... Pete
23rd Dec 2024 2:08pm |
