![]() | Home > Maintenance & Mods (L322) > egr blanking kit for td6 |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
Good work Stan
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
not driven mine yet, but it will take a while for things to settle down and get true mpg readings..i |
took mine for a run down the m4 and got this reading so i'm pretty chuffed at the result so far..
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
Thanks Stan
at 70 mph it was about 27/28.. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
I'm with nicedayforit on this. If you only need to prevent exhaust gases getting into the engine and not the airflow from the intercooler pipe, then ensuring that the EGR valve remains closed by removing the vacuum pipe should produce the same effect? Oh, scarey, nice MPG figure, used to be able to get that in my P38A (V8 petrol) at steady 70, but never anywhere like it with my TD6. I too am working on sorting out gearbox problems before i move onto this one ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Regardless of what the real mpg is by fitting the EGR kit its an improvement and well worth the effort. IMHO
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
i agree 100% any gain is well worth it. Current: TDV8 (3.6) RRS HSE
@stu, my mpg readout is very accurate as i found on a tank to tank calculation i done on a 75/80 mph journey over a hundred miles...result on readout was 24 mpg and 'real' mpg was 23.8 ... |
mine is rubbish then!!! i did over 300 miles in one go last week tank to tank and the trip computer was 6mpg out.. |
Deep Down Member Since: 06 Apr 2011 Location: Deux Sevres Posts: 104 ![]() ![]() ![]() |
Took the vacuum hose off and blanked it with an M4 x 20 screw.
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
I reset my trip about 1500 miles ago and I have averaged 25.5mpg since, which I believe is quite accurate as I compared the displayed mpg a while ago with actual tank top-ups and it was less than 1 mpg out. On a 300 mile round trip to Cardiff a few months ago (no motorways but decent A roads and duel carriageway etc) I averaged 30 mpg No longer FF owner but still interested. Present car Jaguar XE
DaveAngel Member Since: 15 Aug 2011 Location: Cowplain, UK Posts: 205 ![]() ![]() |
Your MPG readings from the computer may not be accurate, but they will be relative.
removing the egr valve and blanking it off is defo the way to go ..i'm getting between 3/4 mpg more at the moment ..it'll need a month or so to get a proper mpg average but its looking good.. |
