![]() | Home > Maintenance & Mods (L322) > 2012 TDV8 Disconnect battery to trickle charge? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3243 ![]() ![]() ![]() |
Yes in a word. Do it whenever I need a top-up John
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 840 ![]() ![]() ![]() |
yes, I use a CTEK MXS 5 and put it on when I am away for a week or so, it is peace of mind for me, but I am lucky in that the power socket is very close to my engine bay when I park at home |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4312 ![]() ![]() ![]() |
I use a Ctek via my 13 pin tow socket using an adaptor I purchased from the forum shop.
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 113 ![]() ![]() ![]() |
Many thanks for the replies, makes the job that much easier if battery disconnection is not necessary.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 ![]() ![]() ![]() |
I attach a CTEK to the white towing socket with the adapter that was in the site shop.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
On a 13 pin plug 3, 11 and 13 are earths, pin 9 is permanent live.
Hi Bob, thanks for the heads up on the pins. Do all three earths need connected to the trickle charger, or is a case belt and braces? Kevin
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 ![]() ![]() ![]() |
+1 Topped up once a week. |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 294 ![]() ![]() ![]() |
Pin 9 positive, pin 13 negative HTH Ivan 2013 Vogue SE SDV8 2013 Freelander 2 SD4 HSE Luxury |
Thanks Ivan for the confirmation 👍👍 Kevin
Warkman Member Since: 05 Dec 2017 Location: Warwickshire Posts: 13 ![]() ![]() ![]() |
I need to put some charge into the battery (4.4 TDV8 2012) as it’s come up with engine error
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I have permanently wired a Ctek socket lead to the rear fusebox and just thread it through the lower tailgate corner so it isn’t trapped when I close the tailgate, then I leave the Ctek Sat on the rear bumper ledge, simple.
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
I install small DEFA Multicharger. Good thing when use Webasto and drive short trips. Just plug in for the night and battery is always full.
KristoffL322 Member Since: 20 Jun 2022 Location: North West Posts: 27 ![]() ![]() ![]() |
I've just fitted a ctek hard wire kit so I can plug in my ctek charger without lifting the hood. Took about 30 mins to do and most of that we extending the ctek wiring as it didn't reach the grill from the battery, no need to remove any parts of the car to run it how I have, not even the grille, you can fish it though with your fingers very easily. Blue line shows the cable run. Ignore the croc clips and block of wood on the battery, I took this photo when I was checking for parasitic draw with my multimeter.
