![]() | Home > Maintenance & Mods (L322) > 2012 TDV8 Disconnect battery to trickle charge? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
Kristoff, I have put a hard wired connection to the battery like yours. I haven’t yet got it without lifting the bonnet. How have you secured the socket to the grill and do you find the Ctek end cap sufficient to prevent moisture ingress? John
Thank you. Will do likewise. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1616 ![]() ![]() ![]() |
I did much the same on my L405, I used a bicycle outer gear cable and a bit of duct tape to “fish” the wire through from the grille to under the bonnet. I regularly add a smear of silicone grease to the plug after giving it a clean, it helps the cover to pop on more easily. |
Good tip about the grease. |
