Home > Maintenance & Mods (L322) > 2012 TDV8 Disconnect battery to trickle charge?
Epson Green
It has been 8 weeks since I used the RR and not surprisingly the battery is struggling to crank the motor into life.
I have an Absar AGM trickle charger but I am unsure wether battery disconnection is necessary for trickle charging. I see the official LR advice is disconnection and removal but I assume this is for charging at high amps.
I have seen posts describing charging through the tow bar socket which sounds like a good idea, however I don’t have a link cable yet, but this should be easy enough to make up for the future.
But for now can I connect direct to the battery without disconnecting the battery?
Many thanks,
Kevin
Post #652425 3rd Jan 2023 12:00pm
Weegie
Yes in a word. Do it whenever I need a top-up John
GAP iiD BT
Post #652426 3rd Jan 2023 12:10pm
pcourtney
yes, I use a CTEK MXS 5 and put it on when I am away for a week or so, it is peace of mind for me, but I am lucky in that the power socket is very close to my engine bay when I park at home
Post #652429 3rd Jan 2023 12:32pm
DrRob
I use a Ctek via my 13 pin tow socket using an adaptor I purchased from the forum shop.
Easy way to top up battery.
Currently unavailable from forum shop Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #652432 3rd Jan 2023 12:44pm
Epson Green
Many thanks for the replies, makes the job that much easier if battery disconnection is not necessary.
I am going to look into making up a link lead to charge via the tow electric socket, it must be straight forward - just the permanent +/- pins to identify. Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #652436 3rd Jan 2023 1:09pm
mjdronfield
I attach a CTEK to the white towing socket with the adapter that was in the site shop.
No issues over the years.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #652448 3rd Jan 2023 2:48pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
On a 13 pin plug 3, 11 and 13 are earths, pin 9 is permanent live.
Plenty of diagrams if you Google it, I made one with a 13 pin trailer socket into a connection box screwed to a piece of wood, just clip charger on or multi gauge if I want to see battery condition 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #652451 3rd Jan 2023 3:49pm
Epson Green
Hi Bob, thanks for the heads up on the pins. Do all three earths need connected to the trickle charger, or is a case belt and braces? Kevin
Post #652453 3rd Jan 2023 4:16pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
No issues over the years. Thumbs Up
+1 Topped up once a week.
Post #652466 3rd Jan 2023 7:37pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Pin 9 positive, pin 13 negative
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #652481 4th Jan 2023 8:37am
Epson Green
Thanks Ivan for the confirmation 👍👍 Kevin
Post #652487 4th Jan 2023 9:52am
Warkman
I need to put some charge into the battery (4.4 TDV8 2012) as it’s come up with engine error
Looking at the battery in situ it’s not easy to see the terminals in where the battery sits.
What do others do when needing to charge? I have a cetek mx7
Many thanks
Post #654127 20th Jan 2023 10:43am
Baltic Blue
I have permanently wired a Ctek socket lead to the rear fusebox and just thread it through the lower tailgate corner so it isn’t trapped when I close the tailgate, then I leave the Ctek Sat on the rear bumper ledge, simple.
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #654132 20th Jan 2023 12:42pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
I install small DEFA Multicharger. Good thing when use Webasto and drive short trips. Just plug in for the night and battery is always full.
Post #654452 23rd Jan 2023 11:29am
KristoffL322
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
I've just fitted a ctek hard wire kit so I can plug in my ctek charger without lifting the hood. Took about 30 mins to do and most of that we extending the ctek wiring as it didn't reach the grill from the battery, no need to remove any parts of the car to run it how I have, not even the grille, you can fish it though with your fingers very easily. Blue line shows the cable run. Ignore the croc clips and block of wood on the battery, I took this photo when I was checking for parasitic draw with my multimeter.
Post #654501 23rd Jan 2023 6:04pm
